Help please. 18x9 +34 offset?
I got some wheels with those specs, and I currently have 20mm Garageline hubcentric spacers (with studs that came on those) on all four hubs. Wanted the stock wheels to sit a little flusher after I lowered the car.
The issue I'm having is when I tried to mount the new wheels up front it didn't clear. It scratched my brembo a little :'( any suggestion's or recommendations on if I should get a universal 5 - 10mm to "safely" clear the front brakes? And if it'll be "ok" to put 5mm or so on already 20mm spacers from these Garageline guys?
Please don't flame, I used the search button already but "spacers on spacers" didn't work.
Anyone else have suggestions on what size spacer I should get? I really don't want to have to buy a set of 25mm for the front JUST to clear when I can easily slap on a 5mm on top :/ I'm not tracking the car or anything lol, just wanted to hear some opinions of what size to get as far as spacer size goes.
Already bought, can't return :/ need to make this work regardless. I read wheel and offset guide here on evo x and thought I was good to go after reading the guide but found out I wasn't the hard way.
When I ran RPF1's on my evo 8 I had to run 20mm spacers up front. I torqued them down to spec, drove on them for about 100-200 miles, then torqued them down again for safety precaution. Guess what, less than 80 miles later the spacer started backing out on my while I was on the highway. The wheel was literally being held on by a few threads. I thanked god that what could have happened, didn't happen.
Ill personally never run a wheel that needs a spacer ever again. Don't be an idiot, if you must run that wheel setup, buy the proper hub centric spacer.
Are you kidding me? Your too lazy to do the SAFE thing and just buy new spacers? I'm glad you feel your life, and/or someone else's life is worth the risk of being cheap and just "adding a spacer on top of another one". Spacers are already a risk as it is.
Last edited by Vizzle; Mar 22, 2015 at 06:34 PM. Reason: nevermind went ahead and bought new spacers.
^ Useless rant but whatever. Just bought a new set of 4x 25mm hubcentric spacers from garageline. If all else fails, I'll just take the continental dw tires off of those new summer wheels and put them on my stock enkei's :/ Was trying to have a summer wheel and winter wheel setup, hopefully the 25mm's will work. Thanks anyway.
that's a crazy spacer and puts quite a bit of torque on the hubs. i dunno, but people do run those quite often and i don't know that i've ever heard of any negative effects.
as long as you are just daily driving on them, i'm sure they would be okay. but don't quote me on that.
Hope so! Garageline doesn't make anything larger then 25mm apparently :/ But with the current spacer I have and being lowered, the car it's fairly tucked atm. Hopefully the extra 5mm I'll get from that 25mm will help it clear. Might be super tight but *fingers crossed* it'll work.
I'll post pictures if I can for anyone that was curious if I can fit them on lol.
(FYI for those who DIY like I do, when you take off spacers or wheels for that matter, you should scrub the mating surface with a wire brush to get the build up that settled inbetween the wheel hub and the hub's surface. You can add anti-sieze or whatever it's called and that stuff to the lug nuts to help keep them nice and tight)
The reason that you haven't heard of any negative effects is that the "torque on the hubs" only depends on final offset (i.e., wheel's offset minus spacer's thickness). Fpr example, a +34 wheel with a 25mm spacer is the same, with regard to the hub, as a +24 wheel with a 15mm spacer.
I'm no mechanic, but after being in the Army for so long and working on Humvee's or LMTV's and other heavy machinery, I learned that getting your hands dirty isn't a bad thing lol. Just sucks tbh, but I learn something about my car everytime I throw it on the lift.
Next thing to do if these end up fitting (after rescrubbing surfaces again etc and putting on the 25mm spacers) is to throw it on the alignment rack and see how she fairs. I saw the rear camber bolt + front bolt on the shocks/struts that you can flip for +/-1*'s. Then I gotta see if the toe's are zero'd as well :/ Seems fairly easy, luckily I have a full shop available to me since there's one on every Army base I've ever been to. nothing a little elbow grease and a will can't fix
Oh... the best thing my buddies and I have picked up from that video is... "YOU'RE CAR IS GAYYYYYY". HAHAHAH, we say it to each other all the time. It's a running joke now :P
maybe. seems like there would be additional load on the hub. instead of it of being placed directly on the hub assembly, it's 25mm to the outside which is harder on the bearings.
speaking of a leverage point of view, that is.
maybe 25mm isn't enough to matter. just thinking out loud.
How else is anyone supposed to learn anything?
If a 25mm spacer isn't big enough to damage anything, it's fine with me and good to know. Makes me feel better about the 20mm I run on the front.
Fwiw, this diagram illustrates what I was thinking:
http://forums.pelicanparts.com/uploads20/Spacer1333685079.jpg
