Upper Mount Substitutes for Ohlins R&T
Gents, kindly seeking for your advices. Sorry, couldn't find relevant thread.
I'm getting Ohlins Road&Track, but without all upper mounts. Rears is not an issue, my inquiry is fronts.
Can I fit some aftermarket pillowball upper mount ( Cusco, etc) to Evo X Ohlins Road&Track front coilovers? Does the Ohlins stock thread allows this? Maybe, I should look for original Ohlins mounts?
Or any other useful thoughts!
Many-many thanks!
Many-many thanks!
Cusco will fit, you will just need the correct adapters (you should select the adapters when you order the plates). Vorshlag is also an option. I used Vorshlag for some time, now I use Cusco. Ohlins replacements are VERY expensive.
Cusco has two different part numbers, 566440CA is beefier and easier to change bearings if needed.
Nimpoc
Apr 14, 2017 01:44 PM
Luffy
44
Jan 16, 2007 01:28 AM
Luffy
37
Oct 16, 2006 06:30 PM
