Outer tie rod ends replacement question
Hello,
Does anyone know whether an outer tie rod end (which I was told by my mechanic needs a replacement due to being worn / loose) is part of Whiteline Front Roll Center Adjustment kit? I've had the Whiteline RCK kit installed for years and I am wondering whether RCK is going bad?
If they are the same part, I might as well get another Whiteline RCK.
If they are NOT the same part, does it make sense to go with OEM part of aftermarket as far as outer tie rod end replacement?
I don't track but I am lowered (Swift Spec-R springs + Whiteline RCK)
Thx in advance
-kris
Thx in advance
-kris
Had a feeling it was the same part; wanted to confirm to be sure.
I had RCK installed July of 2012. Car had 3100 miles back then. Fast forward 4 years (and 17k miles) and it appears one of the outer tie rod ends is going bad. Brake heat-shield was NOT removed. The only other suspension upgrades are springs and rear sways.
So, not a lot of miles driven with RCK since the install (not to mention car hasn't had any track action). Does it seem like a premature failure?
-k
PS
Noob question... Since there are outer tie rod ends, I'm assuming there are inner tie rod ends as well? Whiteline doesn't seem to offer them. Does it make sense to upgrade the inner ones at same time with better than OEMs along with RCK install (assuming that aftermarket ones exist)?
Thx isaachunyu.
-k
PS
-k
PS
https://www.evolutionm.net/forums/ev...-tie-rods.html
krzys4 (Jul 5, 2016)
Its easy enough to jack the car up yourself and take a look. If you move the wheel back and forth while its in the air with your hand you will see the play in that ball joint and feel it.
PAdutch
Oct 28, 2016 11:09 AM
mcm308
33
Apr 5, 2012 05:11 PM
wrxedout
16
Mar 12, 2008 02:08 PM
