Anyone knows where can I get the camber bolt for my kw?
Hi. I bought the used kw v3 for my x, and when I trying to put iron today,
The stock camber bolts doesn't fit the kw v3
It come with vorshlag camber plates so I can still put it on
I am using stock camber bolt to hold it now
So anyone knows where can I get the kw camber bolt?
Or any aftermarket camber bolts are working for the kw
Just let me know.
Thanks
Just let me know.
Thanks
Kw doesn't reply my message. And my friend who sold it to me says
"This was no camber bolts for kw. Just use stock one......"
Anyone here bought the kw v3???
Is it come with the camber bolts??
Where the stock strut uses a 2 position bolt to "adjust" camber, the KW's have an eccentric adjuster bolt/washers in that spot, like what the rear suspension uses to adjust camber and toe. The OEM bolt will not work.
ahh ic yea, I guess you don't have much choice except to order the eccentric bolts from them. Unless the ones for the rear happen to fit there also. But looks a little small for the ones from the rear to work which would be easier to find..
Junkyardspecial
Apr 24, 2016 12:52 PM
overdrive1
Aug 11, 2015 06:13 AM
monstar 8
19
Sep 18, 2007 01:51 AM
mymroadster
Sep 16, 2006 10:35 AM
