Track day alignment questions
Hi I am looking to a alignment done for the track and looking for some suggestions on what specs I should go with
The currently setup I have is -2.5 in the front and -1.5 in the rear with 0 tow front and 0.05 rear the car is lowered but not slammed on FA 500 coilovers This setup was with stock rims and tires
I now have 275/35-18 tires on 18x10 rims and they are close to rubbing in the rear
What I am looking to do alignment wise is -3.5 in the front and -2.5 in the rear with 0 tow front and 0.05 rear with a possible 0.25-0.5 lift to make sure there is no rubbing
Any suggestions for a better alignment? I am trying to not roll the rear fenders
thanks everyone
James
thanks everyone
James
if this is your first time at the track, your current alignment is fine. as you get faster you'll start to figure out what you like and you can start adjusting from there. In my opinion, the seconds specs you posted of what you want to do is a bit much for your first few times at the track.
for the rear toe specs, are you talking toe in or out? I prefer 0 toe all around, but definitely no toe out in the rear
and yes, you absolutely wanna dial out any tire rub before you go to the track. you'll be loaded up in turns for extended periods of time at high speed, not a good combination...
which tires do you have out of curiosity?
yeah I am bringing the car to get the rear fenders rolled friday and probably get the alignment around what you have
One thing I wish i did on my evo was run a little toe out. I have it done on some other cars and although it makes the vehicle kinda floaty in a straight line, turn in was much better.
dbotkin5
Southeast Region
78
Sep 4, 2009 05:54 PM
EGbeater
Jun 16, 2009 10:58 AM
05mazdarx8
Sep 19, 2008 07:57 AM
Mr. MR
Jul 22, 2005 03:00 PM
