HR wheel spacer caused vibration
My GSR was running with stock tires & rims with 20mm HR spacers. I put those spacers when I lowering the car with KW V3 about 2 months ago. But after that I noticed the pretty significant vibration from steering wheel after 80 MPH. At first, I thought it was tire balance issue. But this morning, I took the 2 front spacers off, and the vibration is gone! Car drives stable and smooth even 90 MPH.
Are the spacers hub and wheel centric?
just because a shop installed them doesnt mean it was done correctly, you have to make sure that when the spacer sits against the rotor it does not wiggle around on the hub, i needs to sit flush and snug to make sure its perfectly centered, i have garage line spacers that i run with the stock mr bbs wheels and ive done over 140 mph with absolutely no vibrations.
Whether or not they're hub centric also has nothing to do with who installed them...
nateromero
Sep 17, 2010 06:10 PM
raytrix
22
Jun 19, 2010 04:39 PM
Bernie Fincham
Aug 4, 2008 12:21 PM
DSMEVOLUTION
Jun 15, 2007 06:21 AM
