Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Camber plates for stock - Cusco Front Camber Adjustable Top Mounts
Old May 28, 2018 | 06:07 PM
8OhOh2's Avatar
Cusco Front Camber Adjustable Top Mounts - Mitsubishi EVO X
Code: CUS-566-410-A
MSRP: $320.00
Our Price: $274.00
(You Save: $46.00)
  • INCLUDES 2 MOUNTS, LEFT AND RIGHT
The CUSCO Pillow Ball Upper Mount is an adjustable camber plates that will replace the soft factory rubber upper strut mounts with high strength metal mounts and spherical (pillow ball) bushings. Cusco Pillow Ball Upper Mounts will allow you to adjust your front negative camber well over the factory specs for much better handling. Cusco Pillow Ball Upper Mounts offer a FULL range of camber adjustment but the maximum negative camber allowed for will depend on your entire setup, including ride height. They are designed to work with stock suspension or nearly every aftermarket system available.
Both center lock and camber adjustable type available. 6mm thick plate uses 2017S duralumin.
Camber Adjustment: Camber adjustments can be made using the adjustable type upper pillow ball mounts.
https://www.evasivemotorsports.com/m...Z4A-SUSPENSION
Anybody use these before?
I am looking for a pair of camber plates that work on stock MR suspension.
Kidloco51
Motor Sports Parts
Jul 14, 2017 07:17 AM
aeroweenie
Northwest Region
Apr 18, 2010 09:09 PM
raidokoiv
Feb 12, 2010 08:12 PM
Gruppe-S
Evo 'For Sale' Suspension / Brakes / Handling
Apr 22, 2004 01:51 PM
Gruppe-S
Gruppe-S Engineering - California
Aug 19, 2003 11:45 AM
Quick Reply: Camber plates for stock - Cusco Front Camber Adjustable Top Mounts
