Hawk pads extremely npisy and lots of dust!
I have hawk pads with stock rotors, they worked well for a while, but now they are noisy as hell, squeal every time, and the rotors seems overheated and have lines marked.
Is this a problem with the type of pads? should I replace them? resurface rotors? or change the whole setup, rotors and pads?
Thanks for your reply
Brembo USA sells ceramic pads for reasonable prices at least for the 8/9's. Little to no dust and noise.
https://www.brembostoreusa.com/produ...ad-set/P54039N
https://www.brembostoreusa.com/produ...ad-set/P56048N
May not be as good on track as Hawk but is good for the street. Use some lube on the back of the pad where it contacts the piston and noise should be
no problem (Thin Coat). You will need to clean reuse pins and clips.
Unless you can catch a finger nail on the lines on the rotor you should just leave them alone. Wear is never quite even. Pic looks ok to me. Some lube on the back of the pad might fix what you have. Look for some brand of " Anti-Squeal". Do not get it on braking surfaces or rotors.
Brembo also sell their version B-Quiet: https://www.brembostoreusa.com/brembo-b-quiet/
Mitsuatb
Mitsuatb
If you have life left in the pads, first thing you could try is just removing the pads, cleaning the calipers/pads and greasing everything up (pins, shims, etc.). Then re-bed them. I bought girodisc shims and greased the appropriate spots, still have a little squeal now and again but nothing compared to what it was previously.
FWIW, I've had similar squeal on Hawk (HPS & HP+), EBC, etc. I learned its more about the grease and bed-in procedure vs. the actual pad/rotor. I've thrown money at new pads and rotors before and had the same damn squeal.
Jp7 (Mar 1, 2024)
WRC-LVR (Mar 6, 2024)
I have bought several used pads because the owners/shops failed taming the squeal greasing moving parts/contact points (+ some brake dust) definitely got rid of the squealing for me. I'm refreshing the hubs/rotors/pads currently and this time I want to try RTV on the springs and pins
Poondoggs
Oct 25, 2010 11:58 AM
evolutioner27
10
Mar 20, 2010 04:51 PM
guapoholic
Feb 8, 2010 01:16 PM
