[Article] How to Install Spark Plugs
i noticed you didnt mention it so there's prolly a good reason for it, but shouldn't you replace one plug at a time so you dont forget which wire goes to which plug? Like i said you may have a good reason, i just wanted to know.
By the way, if I remember right the separate wires that fire off the coil packs both have the same length wire and are completely swappable for whatever reason. If you're really **** I suppose you could just lay them out the way you took them out, but it's not necessary.
Czubaka
Apr 11, 2007 06:02 PM
