boost question please help>>>
Most are dialing them in around 22-23psi, but I find that a bit high for stock fuel pump.
Yes you can get it up higher, but when I say your fuel system may not keep up I mean you may be running leaner than you would like.
I bring this up because I run a tune and have recently done some logging and have found that my fuel system can only keep me at the AFRs I want it at if I run 19psi or lower. So I am putting in a new fuel pump. But even if you can run the AFR you want at 25 PSI its not recomended on the stock system.
I suggest doing a search as this topic has been covered numerous times and the info is at your finger tips.
BTW...25psi is not something that is recommended, even with a tune. You will find you are blowing nothing but hot air increasing your chance for detonation.
evilempire18
13
Oct 16, 2010 06:31 AM
JohnathanKong
25
Apr 28, 2005 07:57 AM
