Help. I need to plug my EGT tap.
This should be obvious..... but you need to go to the hardware store and buy a 1/8" NPT Pipe plug.... all pipe plugs should be NPT thread (tapered).
Home Depot and lowe's don't carry below 1/4" so you need to try ace or maybe tractor supply, or something like that...... 1/8" is used for hydraulics so there may be some place around that has supplies like that.
Other option is to find a piping supply store.
Make sure you use anti-seize especially with stainless steel. Although, carbon steel plug should be fine.
Here's a link to a cheap one.... took 2 sec on google.... I'd make sure whatever plug you buy is solid(machined), not hollow (cast), i'm sure you can find local though.
http://www.mfgsupply.com/m/c/AZ8335.html
I had some trouble doing the same thing and finding all of the parts. I would retap the manifold if you can and make sure to go all the way to the top of the tap if you can. And make sure it's not BPT. It's a difference of like 1 thread. One has 23 and one has 24 or somewhere around there.
DDocto
Evo X How Tos / Installations
22
Aug 11, 2013 01:42 PM
black_beauty
10
Feb 5, 2013 01:34 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
Jun 3, 2008 05:48 AM
titaniumkingpin
Sep 10, 2004 05:01 PM
