Evo 8 Problems
Give the car a good look over, drive it, look fo rall the things you would look fo rin buying any car. Is the clutch stock? If so, it probably wasn't beat on that bad. Those mods are minor. Look fo rany signs of aftermarket boost control. If all the stock stuff is still there, and it looks like it's all been there it migh tbe worth it.
Price?
My 03 just went over 50k and the only problem I have had is a bad HID ballast that I changed over. As others staed, the tranny is fine, it's the clutch. Sometimes shifting is a bit notchy, look for that also.
Price?
Alright guys thanks for the info! Ill deffinately look for these things if i go and decide to look at the car.
The first car is in an auction so price is unknown. And not sure who it was driven by.
The second car is for sell by a dealer but its his personal so. And the price is 20999 but im sure i could talk him down a little bit if i decided to buy it. And im guessing hes in his 30's or 40's.
Yea, so I guess this Edmunds article and the 03 Mitsu brochure Im looking at are wrong...
The color might have been called Pacific blue in other markets, but it was BBY here, so why call it anything else? Are we that JDM?
First of all, the BOV was not that bad of an idea as far as long term thinking goes, however not recirculating it, was and can still be done for under $30 if the intake pipe has the recirc tube (it's normally got the crappy plastic one). The big thing your runing into is timing/balance shaft belt changing time, if you put average to above average milage on it. That can get expensive if a shop has to do it. That's my .02 cents worth, also you may want to check out this thread if you haven't already also :
https://www.evolutionm.net/forums/sh...d.php?t=317064
^Thanks for the link...
I got a question that wasnt answer in the thread though:
What's Active Center Differential (ACD)
and also
what gas mileage would i be looking at?
and also
ACD is Active Center Differential. You can switch Between Tarmac, Gravel and Snow and the car changes the power set-up to grip better under that condition. It helps at times, but its EXPENSIVE if you have to do drivetrain work that involves the Transfer Case.
Gas Mileage will be around 20MPG if you drive it moderately. I am getting about 15 but I am heavily modified and have a hard time staying off the pedal.
I would go with the Blue one, as long as the dealers not a dick.
the evo is very very well built. I would not be afraid of 60k. I would have the car looked by a tech that knows evos. Spend a few hundred to have it inspected and then enjoy. The tranny will get tore up with quick shift drag racing, the clutch will get fried when slipped on launching, no different then most any other car used for racing. A well taken care of car is worth a few thousand more then one that has not been taken care of ie... documented fluid changes, fresh brakes if needed (high quality pads), good tires that are matching not some cheap tires that don't match the evo's ability or miss matched tires. My .02 lastly take the hks bov off and put on a mr bov car will perform better. and no acd on the 03.
You don't need to, all you need is a small allen wrench and this 1" tube made for the HKS BOV:
http://www.extremepsi.com/store/cust...at=1007&page=2
That will be able to hold more boost then you probly ever plan on running, however the same can't be said for a stock Evo VIII BOV .
54,000 miles .. high miles .. (super laughs out loud) ... NOT EVOs really are stout if you can verify the owner took pretty good care of it.
All of the suggestions for checking the various component are great!
You will really want to change a timing belt at 60,000 which may be your first really big service issue ...
Good luck on the purchase,
~j.
~j.
