419 Ft. Lbs Stock Turbo Stock Clutch FTW!!!!!
So, let me summarize:
stock turbo - 30 psi
stock injectors - 30 psi
stock cams (and stock springs/retainers) - revving to 8k
Let me guess, you also have full spool at 100 rpm right?
What do you not understand about "It's not physically possible?" The stock turbo, stock injectors can't do that. Period. I do not even care about your whp/wtq numbers.... Those are all relative to what dyno you are being tuned on. The pressure drop the turbo is providing, however, is not dyno specific.
I would LOVE to see your so called tuner chime in and refute what I am saying.
you were were close with full spool it was actually around 1370K but itll work. We'll see im not afraid to take my car to the limit like many are. If it goes ill just rebuild it or build one. We have taken many evo's with stock head to 7.5 to 8k with no issues. Evo heads are very well built! but like i said its w.e you guys wanna post. I just figured id let you all know we have been up to. I didnt post this to start a pissing contest.
Lets see some logs. Lets see some graphs too! You have completely reinvented tuning of the Evo!!! Good job! Why couldn't any of the hundreds of evo tuners in the US figure out how to get 34 psi out of the stock turbo! Hallelujah!
Where is this shop you tune at? Morgantown PA? I am local.
Let me know. i would like to check out this mystery of a vehicle. I wont say its impossible, but I will say its ballsy for sure and a little on the unbelievable side.
If you say so... btw i said it spiked around 34 psi on the run it made 419 what it fell to id say 27ish i donno but it kept good pwer and tq till red line ( and i mean good power and tq for a stock turbo, they rnt made for high rpms and they start to act like a blow dryer). I think the reason we were able to make the power we did was from the fmic, we kept it watered and air to it and intake temps didnt get over 90 degrees.
guys why can't we be supportive....if this is true, its an amazing accomplishment....like the guys said, he doesn't care to take his car to the limits
lets see the graphs before saying it's impossible
Im from morgantown wv, we have a shop in blairsville, pa. And the car is not a mystery car is a fricking daily driver evo with basic boltons and just a real good tuner. i know Nate has consecutively pulled 20,30 and 50 hp out of cars that came from other companies (not mentioning any names). Nate is looked up to alot in the dsm community, i mean he tunes Curt Browns car, Sheps red evo, and was Brent Raus's crew chief
