bg syncroshift in transfer, tranny, and rear diff?
yes i did a search.
I couldnt find any people using bg in all thing listed in topic. is it good to do?
I have bg syncroshift 1 in my tranny, and want to change transfer case oil and rear diff? should i use the same stuff?
NO!!! First of all, its a transmission fluid (and a crappy one at that) so it doesn't belong in the transfer case or rear differential. SmikEvo is right, don't even put it in your transmission. Its thin and sheers very easily so it provides very little protection.
Mitsu factory specs for the drivetrain
transmission: 75W-85 GL-4
transfer case: 90W GL-5
rear differential: 90W GL-5
No offense, but when I was searching for the same things as you everyone was saying how bad it is.
I just replaced transfer case and rear dif with the OEM Diaqueen fluid, and then AMSOIL in the tranny. Works wonders! I didn't believe the hype at first, but now it was def. worth the $51 spent on tranny fluid. I feel a big difference!
I personally use Redline MT-90/MTL mix in my transmission and OEM Mitsu DiaQueen 90W LSD in the transfer case and rear differential.
In these threads the OP's are only talking about BG in the Tranny, there is no mention of using it in the TC and diff.
I would run OEM fluids in transfer case and rear dif. for sure..and then choose something else for the tranny.
