Help me plz, Car wont start
first of all wuddup guys im pretty much a newbie went from an integra to a 2003 evo. Anyways i have a big problem i bought my car like 4 months ago and doesnt wanna start! Ppl were telling me to check the cam angle sensor, check for loose connection, ect.. when the problem first happened i was able to start the car, after messin with it, and sure enough it would start., but it would be fine for a couple of days then it would happen again. I would pretty much repeat the process untill i got tired of it.lol. anyways when it would start i noticed allot of back pressure from the hose connected to the throttle body,it would whiplash like no other,(thinkin it could be the stock bypass valve not opening up all the way) juss a thought. Now ppl are sayin check the wastegate??? ummmmm..(dumb founded) ii have no clue. So someone pls help me i need a ride to go to work i hate relying on ppl to pick me up.
o yea i forgot to mention that it dosent do the clicky click noise, it`ll fire up but wont turn over...i think thats the right term. anyways like i said can someone pls help me im dyin over here without a car. So any advice or suggestions would really help Thanks
Tony
Tony
it`ll crank but wont catch. it doesnt make any sort of clicking, o yea i would like to mention the only code im getting is high idle control does that serve any purpose of it not startin?
Take it to the shop before u really screw it up. If u dont have the cash wait till u do. Sorry to be kinda hard but I know from experience I have tried to fix stuff that I didnt have a clue what I was doing and it ended up costing me alot more than it would have. Good luck man.
yea thats what i was gonna do becuz i dont wanna further go on any other probblems. but what do you mean by the injector pulse.....thanks for advice
o yea i forgot to say i have 85XXX on it
well first i was checkin if i had any loose connections in any of the wires, checked if i was gettin spark and checkin the fuses and relays that was it, o yea and pretty much juss had it sittin for like 30 minutes but now it juss wont start at all it juss sits in the garage
im having the same problem pretty much... it will just crank, but wont turn over.
Mods-
TBE, ETS intake, tune...
i checked the hoses and vacuum lines... didnt work. Made sure MAF was connected... didnt work. Changed Fuel pump... didnt work. I disconnected the spark splug, but left it connected to the coil pack/wire and cranked it to see if there was a spark. Nothing no spark, so im thinking its either the spark plugs are bad, coil packs, or spark plug wires.
Mods-
