Transfer Case Fluid Question On VIII
My friend is nearly done installing my new clutch and asked if I could find out the answer to the following question.
"need Mitsubishi transfercase fluid - amount - and to know how to install and bleed"
Any information would be appreciated.
Thank you in advance!
.58 quarts in t-case and .58 quarts in rear diff. Just make sure that you fill the t-case the CORRECT way otherwise you'll think it's full when it's not and then boom!and did you say, "bleed"?? If you're talking about the ACD system, then you need some sort of ATF fluid and look up how to bleed it in the HOW TO section.
ChuckP
12
Jan 25, 2007 03:32 PM
jrsimon27
Mar 19, 2006 04:45 PM
