AMSOIL Power Foam Engine Cleaner & Degreaser
So i bought this
http://www.amsoil.com/storefront/apf.aspx
and the directions are
DIRECTIONS
Run engine to normal operating temperature and remove air cleaner assembly. While engine is running, spray entire can of foam directly into intake. Turn off engine and allow to sit for 5-10 minutes. Restart engine and drive to blow out deposits.
Now by air cleaner assembly is it talking about the intake filter? or the intake filter + MAF sensor? do i spray thing into turbo intake??
Im not exactly sure where i should be spraying this.....
DIRECTIONS
You take off the upper IC pipe and intake, You will spray it into the throttle body, with the car off you open by hand the TB plate and spray it down into the intake manifold.
You may not use the whole can, and you may do have can this oil chamge and next half next oil change, or use the other half on your other car.
says AMSOIL
says AMSOIL
antilag_200
Jun 9, 2017 07:33 AM
FS[SouthEast]: Good Condition APS Cold Air Intake w/ Amsoil Filter!!**
06MREvo
22
Apr 6, 2016 08:51 AM
FS[MidWest]: K&N Filter with oil and cleaner kit
tmaddox
Jan 5, 2016 06:55 PM
