Help me decide on tires/suspension
My goal for my 05 is to achieve go kart like handling, not 800hp dragster. What tire size would be best? I was thinking going 245-40-17 and lowering the car 1 inch(currently stock height) on a decent set of coilovers. Any advice on what route at should take and maybe better tire combo? Thanks in advance
Why coilovers? If it's not a dedicated track only car, go with Bilstein HD shocks/struts and Swift Spec-R springs. Lowered me 1.3" and handling is phenomenal, very comfortable, no nasty sounds, no maintenance and 100x better than the stock kyb's. No more nose dive is great. Read up on suspension/tires based on what you'll use your car for. I run BFG gforce's and I'll go with Robispec KW V3 coilovers when it's time for a full cage/track use only.
to be installed properly coilovers should be scaled to properly set ride height and preload. bilsteins are pretty straight forward and can be setup to run whatever spring you would like for as good and sometimes better handling the coilovers... especially units costing less then 2k. they can't compete against ohlins but who would expect them to?
as for tires.... nt05s in the size you want will give you a damn good handling street setup... couple it with a 25mm rear sway bar for a lil induced oversteer and possibly a wider front track width and you will be cutting up corners with the pro's for under what they paid for their coilovers alone... don't expect to set world record times... but i promise your boy's with s2k's wont be able to call your car a fat pig anymore...
I would suggest the nt05's in 245/40/17 as well.... Also look into bc coilovers if thats what your looking for, read up alot of good reviews on them and will be switching my tein ra's to bc's very soon. Hell of a good price on them
Coilovers shouldn't see weather and road grime or they tend to cease up, the adjustment threads get ruined and they usually have to be rebuilt regularly (10k miles or so) usually. For the $1,300ish price you'll pay for Bilstein HD's/Swift Spec-R's you're way ahead of any coilover set in the same price range, if you're using them on the street. All you'll gain is a jarring, loud, pain in the *** ride. Like Joe said, you have to spend upwards of $2k or more to get a seriously good coilover system that will be worth all the trouble.
Im not tryna to rebuild coilovers every 10k miles, F that. Are the more expenssive ones less hassle? lets say I just go with bilstein and swift spec-R's, how much improved will my handling be. would you guys recommend 245 tires over 255's? im keeping stock wheel for now. thanks
Mitsubater
Jul 31, 2011 05:56 PM
Bergen Automotive
45
Jul 3, 2010 11:53 AM
TheRaGuy
11
Sep 20, 2005 04:48 AM
