Oil Change frequency
Old Nov 4, 2013 | 04:33 PM
bikerbud76's Avatar
Im new to the group. I read the theads in this room and did not see any info on this: I Just purchased a 2014 MR. Took it to mitsu dealer (shreveport, la) for my first oil change. Book says synthetic. Mitsu did oil change (synthetic plus "additive") and puts my next oil change after 5K miles. It has been 2K miles and odo reads 5750 and my regular maintenace service light is already coming on. Oil level good. I assume 5K was good coming from a mitsu dealer service. Book says every 3K. I called mitsu in plano where I purchased the car. They said every 3K and use regular oil ("does not require synthetic"). Im confused. My first concern is my warranty and my extended warranty. Next of course is the possible adverse effects on my car. Any feedback, suggestions, or advice? I surely would appreciate it.
Thanks.
Gene
Ruston, LA
Old Nov 7, 2013 | 10:33 AM
Yeoldsippage's Avatar
Thanks.
Gene
Ruston, LA
Well it says on the engine cover use Mobil 1, which is synthetic, I'd stick with that, and I always change my oil every 3k no matter what
Old Nov 7, 2013 | 10:37 AM
xXANCHORMONXx's Avatar
Every 3k and use synthetic. **** the dealer.
Old Nov 7, 2013 | 11:23 AM
Yeah I've heard a lot of stories of the dealers telling people **** that's completely untrue
Old Nov 7, 2013 | 11:52 AM
Kendogg's Avatar
My 2012 GSR and my 2103 GSR did not have a mobile 1 sticker on the engine or engine cover. The dealership says those cars are sold with conventional oil in them. And if you go to the dealership for an oil change, they will try and put conventional oil in it.
OP...I would change every 3k with synthetic unless you drive the car hard often. Then you may want to change even more frequently. If the car is stock and you hardly ever get on it, you may be able to push it to 5k miles.
Old Nov 7, 2013 | 12:35 PM
Kracka's Avatar
The service reminder is just a timer, the dealer probably forgot to reset it with your last oil change. All Evos came with and require synthetic oil regardless of what your dealership says; the Mobil 1 stickers have disappeared from the engine covers though.
I change my oil every 4-5k miles with Mobil 1 10W-30 EP; if I didn't have an aftermarket turbo I wouldn't bother with the Extended Protection stuff.
Old Nov 7, 2013 | 07:06 PM
arsing116's Avatar
I've got a 14 GSR arriving in the next couple of days and I've read about the conventional oil coming from the factory. Crazy! Why the switch Mitsu? I called my local Mitsu dealer and they said they are supposed to fill with conventional oil. I picked up some Pennzoil ultra 5w-30 and will switch when it arrives. I plan to change every 3000 miles.
Old Nov 10, 2013 | 10:02 AM
4RETECH's Avatar
Of course from the factory it comes with conventional oil.
Synthetic oils will never seal the rings in properly.
Thats why when we rebuild engines, its always first load of oil as a conventional break in to seal rings.
But the dealer is stupid to say thats what you should use since after the first 1,000 miles your rings are pretty much seated.
Old Nov 12, 2013 | 05:34 AM
yuriyz's Avatar
With fully synthetic oil I would change every 5k miles but I would definitely check the color of the oil around 3k just to be sure. It all depends on how hard you drive your car.
EvoKnievel77
Jan 27, 2017 08:54 PM
apagan01
Sep 24, 2014 02:57 PM
pckiller00
Feb 10, 2014 07:59 AM
bikerbud76
13
Nov 30, 2013 08:19 PM
arm07
Canadian Forum
Oct 10, 2004 12:50 AM
Quick Reply: Oil Change frequency
