Coswort / manley / kelford / act / exedy & more!
Hey folks,
We've got a ton of great products available for the EVO X and we're offering some great prices. We are a direct distributor for Cosworth, ACT, Manley and several other brands so with out middle men, we can offer you some great prices! Check out what we've got on sale and let us know if you have any other questions!
REMEMBER, WE WILL NOT BE UNDERSOLD!
![](http://www.cosworthusa.com/_images/common/logo.gif)
Slowboy is a direct distributor of Cosworth and we've got great products available right now at excellent prices! check it out!
1. 4B11 Stroker Kits!!!!
![](http://d5otzd52uv6zz.cloudfront.net/group-c70955b9-421d-4646-855f-f87c16bcf2e4-350.jpg)
Cosworth stroker kits are the perfect way to add displacement, torque and power to your engine. Each kit includes select matched components from our parts list ensuring reliable performance.
Mitsubishi 4B11 (Evolution X) 2.2L
![](http://d5otzd52uv6zz.cloudfront.net/af4bb087-9847-4be4-bbf6-a778460271c4-420.jpg)
Cosworth pistons really take forged technology to the next level. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth pistons are manufactured using the same methods as our Formula One pistons and include features such anti scuff skirt coating, ultra-strong pins, polished top and patented antidetonation bands. We have various bore sizes available!!!
Key Features
![](http://d5otzd52uv6zz.cloudfront.net/c790b0be-0279-4926-97b7-a7553362fa00-420.jpg)
Cosworth High Performance Head Gaskets are engineered to seal in power under the most demanding conditions. Constructed from stainless steel with a folded stopper layer, each application features superior sealing compared to conventional multi layer steel gaskets. Additionally, Cosworth High Performance Head Gaskets are manufactured from pre-coated die cut stainless steel resulting in uniform coating distribution and consistent shape.
Key Features
![](http://www.cosworthusa.com/store/pc/catalog/20006025_43_general.jpg)
Essential for high performance engine builds, heavy duty head studs reduce cylinder head movement in high boost or high compression engines optimizing cylinder head to block sealing. Cosworth Ultra High Performance Head Studs are manufactured from H11 tool steel with 260,000psi tensile strength and come complete with nuts and washers. Manufactured with hex broach end for ease of installation. Additionally, genuine Cosworth head studs utilize a base seating feature to evenly distribute maximum load on the stud and not the threads. This feature is typically found only in high level race engines.
Hit the PM button and put Hey Marti in the subject and I'll get you some EXCELLENT PRICING. If you email me at mar@slowboyracing.com with your full name, i can send you back a complete estimate for you to look at.
- Cosworth Forged Pistons (86mm)
- Cosworth Fully Counterweighted Billet Crankshaft (94mm)
- Cosworth Forged Connecting Rods
- Cosworth Piston Rings
Key Features
- Unique forgings for each application
- ‘Xylan’ anti scuff skirt coating
- Polished tops (reduces carbon build up and relieves stress)
- Manufactured from proprietary alloy (CosAl 010)
- Ultra strong pin
- Patented anti-detonation bands
Key Features
- Individual die cut layers of stainless steel with superior consistency compared to laser cut gaskets
- Pre-coated stainless steel with a 0.25 micron layer of nitrile rubber ensures consistent distribution of coating with no high or low areas
- Manufacturing dimensional tolerance of +/- 0.001”
- Die cut manufacturing process ensures smooth edges, unlike laser cut gaskets
- Cosworth gaskets feature a “folded stopper” layer for additional torque around each cylinder. The width of sealing area is specific for each application thereby providing ultimate sealing properties
- Available in a range of thicknesses for specific applications
Manley Performance! Pistons , Rods & Spring/Retainer kits!
Manley is one of our favorite product lines and we think that once you see the quality, performance and value, you'll be a big fan too! Check out the great Manley products that we have available for your EVO X!
1. Manley Performance Forged Pistons!
![](http://www.manleyperformance.com/sc/img/pts/piston_mitsu.jpg)
Manley pistons are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Perfect ring groove to skirt squareness is achieved through our unique "one fixturing" manufacturing method that assures maximum horsepower. Round wire locks, tool steel wrist pins, and rings are included with every set at no additional charge.
-9:1 Compression
-86 and 86.5mm sizes available
2. Manley Forged Rods
![](http://www.manleyperformance.com/sc/img/pts/i-beam.jpg)
Manley Pro Series connecting rods are forged from aircraft quality 4340 vacuum degassed material. Each rod is fully machined in the Manley Lakewood, NJ factory to the highest standards. Our signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Bores are round and without taper. Bend and twist is tightly controlled. Cap fasteners are 3/8" APR 2000 cap screws. These are as good as it gets! You can throw just about anything at this block with these rods!
3. Valve Spring and Retainer Kits!
![](http://www.manleyperformance.com/sc/img/pts/kits.jpg)
Manley valve springs are wound from super clean alloy. Each design minimizes stress to ensure long service life with high lift camshafts. Retainers are manufactured in our own double spindle CNC machines to exacting tolerances and precise installed height specifications. Valve locks are manufactured in our own Swiss turning centers with rigid control over the all-important angle to ensure precise mating with the retainer.
-9:1 Compression
Kelford Cams & Springs!
![](http://www.camshaftshop.com/components/com_virtuemart/shop_image/product/214_A_Camshaft_492bad89c8752.jpg)
Kelford 214-A
264 Duration, 10.00mm Lift. EXO X Stage 1 camshafts to suit stock valve springs.
PM For GREAT Price!
![](http://www.camshaftshop.com/components/com_virtuemart/shop_image/product/214_B_Camshaft_492bada376076.jpg)
Kelford 214-B
270 Duration, 11.00mm Lift. EVO X Stage 2 camshafts, requires Kelford valve spring.
PM for GREAT Price!
THESE ARE ON THE SHELF HERE AT SLOWBOY! No Drop shipping!!!
Remember, we won't be undersold!
Hey folks!
Today is blow out day! Slowboy racing is offering huge savings on everything in stock!
And when I say we got it all, I mean we got it all!
Rods, Pistons, Cranks, Cams, Clutches, Flywheels, Turbos, Injectors and much much more!
Call us today, even it's just to get a quote. You will not be disappointed!
![](http://www.slowboyracing.com/splash_page/top_bar.jpg)
REMEMBER, WE WON'T BE UNDERSOLD!!
214b, advertising, connecting, coswort, distributor, evo, evolutionm, kelford, manley, performance, pistons, rod, rods, sizing, specs, spring, valve
