ETS Mitsubishi Evolution X Engine Build Components!
Bottom End Components
Below are the lower end components used in the ETS Engine Build. We have tested the following parts to 718whp with no block or head work. The pistons are standard bore and work great. We did have to eliminate the oil squirters due to the design of the pistons.
Cosworth Bearings - $162.00 Shipped
Engine bearings are one of the most vital components within an engine and are often overlooked when considering high performance upgrades. Performance engineered, multi-layer bearings generate less heat than normal bearings by reducing friction. Cosworth Race bearing sets feature a unique combination of design, metallurgy and engineering to deliver performance in extreme conditions.
Cosworth Race bearings sets are available in 3 sizes to accommodate most applications.
Bearings are sold in sets only.
20007172 Mitsubishi Evo X 4B11T (2.0L) Main Bearing Set-Tri Metal - Size 0
20007175 Mitsubishi Evo X 4B11T (2.0L) Rod Bearing Set-Tri Metal - Size 0
20007173 Mitsubishi Evo X 4B11T (2.0L) Main Bearing Set-Tri Metal - Size 1
20007176 Mitsubishi Evo X 4B11T (2.0L) Rod Bearing Set-Tri Metal - Size 1
20007174 Mitsubishi Evo X 4B11T (2.0L) Main Bearing Set-Tri Metal - Size 2
20007177 Mitsubishi Evo X 4B11T (2.0L) Rod Bearing Set-Tri Metal - Size 2
20007178 Mitsubishi Evo X 4B11T (2.0L) Thrust Bearing Set: STD
Cosworth Rods - $974.99 Shipped
The connecting rod is the vital link between the piston and power. When engine output is increased, the demands placed on the connecting rod increase as well. To ensure engine reliability in all conditions, original connecting rods should be replaced with heavy duty specification parts. Cosworth Forged Connecting Rods are manufactured from high strength 4340 (EN24) steel and machined to precise tolerances.
Cosworth Pistons - $998.00 Shipped
The piston is one of the most important components within the engine. It can be subjected to directional change up to 285 times every second and must withstand acceleration forces of 8500g. Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth pistons are manufactured using the same methods as our Formula One pistons and include features such anti scuff skirt coating, ulta-strong pins, polished top and patented anti-detonation bands. Additionally, each application uses a unique forging to minimize weight and ensure the strongest possible piston design
Cosworth Head Gasket - $139.99 Shipped
Cosworth High Performance Head Gaskets are engineered to seal in power under the most demanding conditions. Constructed from stainless steel with a folded stopper layer, each application features superior sealing compared to conventional multi layer steel gaskets. Additionally, Cosworth High Performance Head Gaskets are manufactured from pre-coated die cut stainless steel resulting in uniform coating distribution and consistent shape.
- Size 1 bearings are a nominal standard size and are used for most applications.
- Size 2 bearings feature an additional .025mm or .001inch clearance and should be used when extra clearance is required.
- Size 0 bearings are available if you require a less clearance than our Size 1.
- Size 0 provides .025mm or .001" less oil clearance than our size 1 bearing
- High strength overlay plate with reduced thickness for better oil control and less
- friction
- Hardened steel backing on all connecting rod bearings
- Increased crush and elimination of flash plating
- 3/4 grooving on Main Bearings providing optimum oil supply
- Tight consistent wall tolerances
- Oversize chamfers where applicable
- Flash plating eliminated for improved heat transfer
- Tested to over 1000 horsepower
- Anti Scuff Skirt coating (Coscoat 1000)
- Polished top (reduced carbon build up and stress relief
- Manufactured from proprietary alloy (CosAL 010)
- Ultra Strong Pin
- Patented Anti-detonation bands
- Set of 4 includes Pins and pin locks
- Performance Ring Sets available separately
- Engineered specifically for sleeved large bore applications
- Individual die cut layers of stainless steel with superior consistency compared to laser cut gaskets
- Pre-coated stainless steel with a 0.25 micron layer of nitrile rubber ensures consistent distribution of coating with no high or low areas
- Manufacturing dimensional tolerance of +/- 0.001
- Die cut manufacturing process ensures smooth edges, unlike laser cut gaskets
- Cosworth gaskets feature a folded stopper layer for additional torque around eachcylinder. The width of sealing area is specific for each application thereby providing ultimate sealing properties
- Available in a range of thicknesses for specific applications
- 20000909 Mitsubishi Evo 4G63 VII-IX (2.0L) Bore = 86mm T = 1.3mm
- 20000910 Mitsubishi Evo 4G63 VII-IX (2.0L) Bore = 86mm T = 1.5mm
- 20001689 Mitsubishi Evo IX 4G63 (2.0L) Bore = 86mm T ~ 1.3mm MIVEC
- 20001690 Mitsubishi Evo IX 4G63 (2.0L) Bore = 86mm T ~ 1.5mm MIVEC
- 20001689 Mitsubishi Evo 4B11T X (2.0L) Bore = 86mm T = 1.3mm
- 20001690 Mitsubishi Evo 4B11T X (2.0L) Bore = 86mm T = 1.5mm
- 20004122 Mitsubishi Evo 4B11T X (2.0L) Bore = 87mm T = 1.1mm
- 20004123 Mitsubishi Evo 4B11T X (2.0L) Bore = 87mm T = 1.3mm
maperformance
Evo 'For Sale' Engine Internals and Drivetrain
Jan 22, 2015 12:05 PM
Vivid Racing
Evo 'For Sale' Miscellaneous
10
Apr 8, 2013 01:52 PM
downforceinc
21
Jul 8, 2012 09:17 PM
Speed Element
Feb 27, 2008 11:34 AM
Caliente Auto
Aug 1, 2006 05:35 PM
