EVO X Engine Builders Thread!
we have seen the demand for 4B11 Engine parts BOOM in the past few months. People seem to be stepping up the game in a very big way! We've very excited about a lot of the options that we have and work very hard to make sure to offer the best at the very best prices!
Through out this thread, we'll have tons of pre-set packages offered in this thread to help your decision making as simple as possible! If you're looking for something specific, let us know and we'll make it happen!
Manley Performance Short Block Internals!
We're one of the biggest distributors in the world for Manley! Their extensive product line offers some of the very best block parts available! Check out some of the great products that we have available.
Manley Platinum Series Pistons:
Manley pistons are machined of high strength 2618 material. Each design is lightweight yet robust enough to deliver long service life. Perfect ring groove to skirt squareness is achieved through our unique "one fixturing" manufacturing method that assures maximum horsepower. Round wire locks, tool steel wrist pins, and rings are included with every set at no additional charge.
We have 86 and 86.5mm pistons available for your 4B11!
Manley H Beam & H Beam PLUS Connecting Rods:
Manley "H" Beam connecting rods are manufactured from 4340 forgings to the same exacting standards developed and approved by our original equipment customers. There is a vast difference in quality between a Manley "H" Beam and the "other" inexpensive H-Beams on the market. Weight matched to +/- 1.5 grams. Perfectly round big and small ends. Bend and twist is tightly controlled. Cap fasteners are 3/8" ARP 2000 for the "H" Beam and 3/8" ARP Custom Age 625+ for the H-Plus.
THESE ARE OUR BEST SELLING ROD!
Manley I Beam TURBO TUFF Connecting Rods:
Manley Pro Series connecting rods are forged from aircraft quality 4340 vacuum degassed material. Each rod is fully machined in the Manley Lakewood, NJ factory to the highest standards. Our signature "Turbo Tuff" design combines the appropriate weight and rugged strength for ultimate horsepower applications. Each rod is shot peened after machining and magnafluxed. Bores are round and without taper. Bend and twist is tightly controlled. Cap fasteners are 3/8" APR 2000 cap screws.
BUNDLE PACKS!
Manley Platinum Series Pistons (86mm or 86.5mm)
Manley H Beam Rods
Shipped
$729
BUNDLE PACKS!
Manley I Beam Turbo Tuff Rods
Shipped
$1129
BUNDLE PACKS!
Manley H Beam Rods
Shipped
$729
BUNDLE PACKS!
Shipped
$1129
Wiseco Pistons for the 4B11!
Wiseco is one of the world's premiere pistons manufacturers. Wiseco Sport Compact pistons are made from dedicated forgings produced in-house to give you a light weight piston with superior strength and optimal design. Being the multivalve piston technology leader, the line features specially designed valve pockets, complex dome and crown shapes, the steel nitride/napier xx rings and optimized skirt profiles. The pistons come standard with our ArmorGlide® coating material for reduced friction and noise, freeing up horsepower.
The Wiseco Pistons are available in 86mm / 86.5mm / 87mm and 88mm bore with 9:1 compression!
BUNDLE PACKS!
Wiseco Forged Pistons 86mm / 86.5mm / 87mm and 88mm
Manley H Beam Rods
Shipped
$749
BUNDLE PACKS!
Shipped
$1149
How about a big dog, Cosworth Stroker Kit?!
Cosworth stroker kits are the perfect way to add displacement, torque and power to your engine. Each kit includes select matched components from our parts list ensuring reliable performance.
Mitsubishi 4B11 (Evolution X) 2.2L
- Cosworth Forged Pistons (86mm)
- Cosworth Fully Counterweighted Billet Crankshaft (94mm)
- Cosworth Forged Connecting Rods
- Cosworth Piston Rings
Take your 4B11 to all new heights!!!!!
Nice kit How much are they?
Any other manufacturers offering cranks?
Cosworth USA!
Cosworth offers one of the most complete catalogs of 4B11 Parts! Their products are some of the very best in the business and can help you achieve any performance goal!
Check out some of the quality Cosworth Engine Products we have available for your 4B11!!!
4B11Forged Pistons
Available in:
4B11 Forged Piston Set - 86.5mm 9.0:1CR
4B11 Forged Stroker Piston Set - 86mm 9.0:1CR with 94mm crank
4B11 Forged Stroker Piston Set - 87mm 9.0:1CR with 94mm crank
4B11 Forged Piston Set - 87mm 9.0:1CR
4B11 Forged Stroker Piston Set - 86.5mm 9.0:1CR with 94mm crank
4B11 Forged Stroker Piston Set - 86mm 10.0:1CR with 94mm crank
4B11 Forged Stroker Piston Set - 87mm 10.0:1CR with 94mm crank
Cosworth high performance forged pistons are designed and engineered to withstand this type of punishment and still perform. All Cosworth pistons are manufactured using the same methods as our Formula One pistons and include features such anti scuff skirt coating, ulta-strong pins, polished top and patented anti-detonation bands.
Billet Crankshaft:
One of the most effective ways to add power and performance is to increase the displacement of the engine. Our 2.2L billet stroker crank for the 4B11 is machined from EN40B steel with a 94mm stroke. Designed for use with Cosworth forged stroker rods and pistons resulting in a perfect bore to stroke ratio that will allow the engine to still rev over 9000 rpm with a broad power band.
4B11 Stroker Kit
H11 Head Stud Kit
Engine Bearings
Size 1 bearings are a nominal standard size and are used for most applications.
Size 2 bearings feature an additional .001" more oil clearance than factory.
Bearings are sold in sets only.
4B11Forged Pistons
Available in:
Billet Crankshaft:
4B11 Stroker Kit
H11 Head Stud Kit
- Essential for high power applications
- Superior strength compared to other brands
- High clamping force helps to seal block to cylinder head joint
- Hex broach ends ease installation
- Roll Die formed threads
- 260ksi+ (260,000psi+) tensile strength
- Special heat treat process includes heating in vacuum sealed furnace and quenched in a nitrogen chamber for precision control
Engine Bearings
- High strength overlay plate with reduced thickness for better oil control and less friction
- Hardened steel backing on all connecting rod bearings
- Increased crush and elimination of flash plating
- 3/4 grooving on Main Bearings providing optimum oil supply
- Tight consistent wall tolerances
- Oversize chamfers where applicable
- Flash plating eliminated for improved heat transfer
- Tested to over 1000 horsepower!
SBR INC
Nov 26, 2016 07:39 AM
Speed Element
Feb 29, 2016 02:25 PM
Girodisc Martin
Evo 'For Sale' Suspension / Brakes / Handling
40
Oct 11, 2013 09:40 AM
