Pre-Order GReddy SST Cooler and Oil Cooler Kits!!!
MR owners know that the SST, when under high power applications, starts to take a beating. Keep the trans and oil fluids in your Evo X cooler and save a lot of strain on the motor and trans with these kits from GReddy!!
SST Cooler
The GReddy SST Cooler Kit uses an additional independent system with it's own compact 160l/hr pump for superior cooling. It is easily installed by connecting to the existing fluid "Filler" and "Drain" ports on the transmission case. (NO machining required.) The V-mount arrangement is mounted in the front left inner fender under the factory unit (and to fit it, it also includes a new aluminum I/C outlet piping.) Another benefit is that vital areas, like the Radiator, are not covered. The kit also includes carefully designed Inlet and Splitter Ducting to evenly divide and control airflow through both the GReddy and OEM cores, while the Outlet Ducting helps increases flow. The V-mounted 12row (-08) GReddy core takes advantage of the airflow under the vehicle to draw out even more air through the core, (while the stock core has to fight with the air turbulence of the spinning wheel in the wheel well.)Also included are precise patterns for trimming of the under liner.
GReddy SST coolers can be activated by a manual switch or by the GReddy MSS (Multi Switching System.) $112 additional.
$1650 MSRP.. PM for Introductory pricing!!
Oil Cooler
The GReddy Circuit Spec Engine Oil Cooler Kit mounts in the right inner fender under the factory core. Like GReddy's other Circuit spec kits this V-mounted 14row (-10)core uses their signature inner fin technology for high efficiency. This greatly helps improve the durability of the engine oil and in turn the life of the engine. The kit adapts to the factory cooler and routes the oil in series, for a simple install. The kit also features carefully crafted Inlet, Splitter, and Outlet Air Ducting to increase flow to and through both the GReddy and factory coolers. Light-weight Nylon-braided hose add to the upgrades on this kit; as does the necessary trimming patterns for a perfect fit.
$920 MSRP.. PM for Introductory pricing!!
We ONLY have 5 of each in coming at the end of the month!! Get yours on hold NOW!!
SST Cooler
Oil Cooler
