PRS shortblocks Sleeved, Ported heads Cams Pistons Clutch packages Install services
Performance Race Solutions
You may ask who are we? We have been in business for 3 years under our name and have been growing each year significantly. We have a state of the art machine shop with a machinist with over 30 years experience. His experience consisted of 100s of evo/ dsm engine builds and really shines in his cylinder heads. We also offer full in-house tuning and installation services for those of you local to us or would be interested in shipping your cars to us for a build.
Email or call us today with any questions or to place an order
http://www.youtube.com/watch?v=OkElw...re=context-cha
PRS Stage 2 shortblock, 6266 on c16
We offer built shortblock packages to fit your needs, we highly recommend sleeving the Evo X blocks if you want to make excessive 450hp.
PRS Stage 1 2.0l Short Block Includes:
Wiseco Pistons
Manley H-Beam Rods
ACL Race Series Rod & Main Bearings
All freshly bored and honed to each specific piston with a torque plate
Freshly Resurfaced
Balanced Assembly Including Crankshaft
Build Sheet
**GOOD CORE REQUIRED: Block must be complete with crank, 5 main caps, oil squirters, crank ring, and all components, cylinder walls must be undamaged
$2600 A good core is required, if you do not have a good core one can be provided.
PRS Stage 2 2.0 Sleeved Short Block Includes:
Wiseco HD Coated Pistons (86mm)
Darton MID sleeves
Manley Turbo Tuff I-Beam Rods
APR Main Studs
Freshly Resurfaced
$4500 + CORE
We also offer EVO X head packages Give us a call with any questions to figure out what suits your needs. We will need your cams along with a good useable core to properly set up valve lash for all of our Evo X heads. We can provide new cores & Cams
PRS Cylinder heads
Stage 1
Includes:
•Clean / Hot Tank
•Visual Evaluation / Inspection
•Deck Resurface to High Performance RA Specs
•5 Angle Radius Valve Job (Performed with Serdi 3.0 which provides the finest valve jobs in the industry)
•New OEM Valve seals included ($150)
•Assembly & Vacuum tested
•New Shim buckets for proper valve lash clearance
$825
Add New Valve locks (keepers) $50
Add PRS SS Valves in OE or +1mm for $225
Add BC Valve springs and Titanium retainers for $215
Add Supertech Dual or GSC beehive w/ titanium retainers for $365
Add GSC S2 cams for $525
EVO X Stage 3 head almost finished still needs decking and final assembly pm for details NO Core needed!
