COBB Tuning Intercooler Hard Piping Kits Mitsubishi Evo X!
COBB Tuning Intercooler Hard Piping Kit Mitsubishi Evo X 2008-2013
The revised COBB Intercooler Hard-Pipe Kit now comes in two great looking powder coated finishes and now fits on GSR, MR and MRT models!
This kit replaces all intercooler pipes (including the BPV pipe) with weld-free single-pipe aluminum tubing.
This uncompromising kit has the most comprehensive list of performance enhancing features available.
Add the precision fit and one-of-a-kind appearance and it is clear that the COBB Intercooler Hard-Pipe kit for the EVO X is unequaled.
Click here See all of COBB Tunings Piping Kits, Learn more about them or to Purchase
You can also purchase the Lower and Upper Piping kits Separate!
COBB Tuning Upper Piping Kits
As with all intercooler hard-pipe kits, the stock rubber hoses to the intercooler are replaced with solid pipes to eliminate distortion under boost. But the devil is in the details, and that is where similarities end. The COBB EVO X Intercooler Upper Hard-Pipe Kit consists of single piece pipes made from mandrel bent aluminum tubing. The results are weld-free pipes from the turbo outlet to intercooler inlet without unsightly mid-pipe silicone hose couplings that can disrupt flow or potentially blow off under boost. The pipe diameter has increased from the stock 2.375in to 2.5in, enhancing flow even further.
The By-Pass-Valve (BPV) gets its own hard-pipe from the cold side of the intercooler, maintaining the factory location and orientation. Retaining this connection from the cold side ensures that cool air is fed back to the intake system when the valve is in bypass mode, preventing overheating of the air-charge post turbo. The BPV is located using a unique COBB logo bridge that connects the BPV hard-pipe to the hot side hard-pipe.
The COBB EVO X Intercooler Upper Hard-Pipe kit is one of the very few that will fit with the factory air box in place (or the optional COBB SF Intake) as well as the stock front engine cover. The kit is completed with high quality COBB silicone hose couplings and heavy duty T-Bolt hose clamps to eliminate those embarrassing hose blow-offs than can occur when demanding the most from your EVO X.
COBB Tuning Lower Pipe Kit
Remember that all order for $200 in the continental US get Free Ground Shipping!
Thanks,
Dallin
