*AMS PRODUCT RELEASE* EVO X Fuel Rail
The AMS EVO X Fuel Rail provides increased fuel flow which is necessary at higher boost levels. This CNC’d aluminum rail comes anodized in Red or Black and includes our signature AMS logo. With a -6AN (7.5 mm) diameter inlet and outlet it dwarfs the stock rail by over 25% in flow area. This is true bolt on part that will install with your factory fuel lines, fuel pressure regulator and will work with all factory style fuel injectors. In addition it comes with a 1/8” NPT port where you can mount a fuel pressure gauge or use it for an auxiliary fuel port.
Included in our kit is a -6AN braided fuel feed line that increases fuel flow by 25%. Our line also makes your car safer by eliminating the hard factory fuel feed line that can crack over time from engine vibration.
![](http://www.amsperformance.com/store/images/evoxfuelrail%20copy4%20(1).jpg)
![](http://www.amsperformance.com/store/images/evoxfuelrail%20copy4%20(3).jpg)
![](http://www.amsperformance.com/store/images/evoxfuelrail%20copy4.jpg)
![](http://www.amsperformance.com/store/images/evoxfuelrail%20copy5.jpg)
Features
Specifications
Options
Applications
Retail: 239.95
Click HERE to Order!
Features
- Precision CNC machined from 6061 billet aluminum
- -6AN (7.5mm) fuel inlet increases fuel flow by 25%
- Thick flanges and stantions for durability and reliability
- Direct bolt-on, no modifications needed
- AMS Logo CNC’d into the face of the rail
- Retains factory fuel pressure regulator
- Works with all factory style fuel injectors
- Available in anodized Red or Black
Specifications
- CNC machined 6061 billet aluminum
- 7.5mm inlet and 11mm return port
- .25 inch thick flanges
- 1/8” NPT port with removable stainless steel plug
- -6AN black braided fuel feed line with black anodized fitting
Options
- Red or Black anodized
Applications
- Mitsubishi Evolution X GSR & MR
- Fits all USDM, JDM and European Models
Retail: 239.95
I dont think anyone has tested the actual limit of the factory rail just yet. We just saw a big restriction like that of the VIII rail and saw a need to make a better higher flowing version. This would be something to do to the car when changing injectors as you have it apart anyway.
There is no negative to adding this rail what so ever.
Eric
Eric
Any chance of building a black anodized model without the AMS logo? Not that I don't like it as is, just trying to NOT give po po any reason to take my car away. ![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
Nice work guys.
Nice work guys.
Chris@nolimitmotors
EvoX 'For Sale' External Engine / Power
Mar 14, 2013 01:28 PM
RallySport Direct
Feb 6, 2013 07:52 PM
FiD-Turbo.com
30
Apr 18, 2011 06:25 PM
Boomba Racing
Sep 30, 2009 07:45 AM
AutoMotoSports
Nov 17, 2008 01:18 PM
