ETS - Extreme Turbo Systems Evo X Product Lineup!
ETS Mitsubishi Evolution X Downpipe - $440.00
Features:
ETS Mitsubishi Evolution X Test Pipe - $259.00
Features:
ETS Mitsubishi Evolution X V2 Exhaust System - $849.00
Features:
ETS Mitsubishi Evolution X Intercooler Kit - $943.95
Features:
ETS Mitsubishi Evolution X Intercooler Only - $499
features:
ETS Mitsubishi Evolution X Complete Piping Kit - $493.90
Features:
ETS Mitsubishi Evolution X Lower Intercooler Piping Kit - $284.90
Features:
ETS Mitsubishi Evolution X Upper Piping Kit - $240.90
Features:
ETS Mitsubishi Evolution X Intake - $271.95
Features:
ETS Mitsubishi Evolution X T3 Turbo Kit - $3600 (First 5 Customers)
For serious power upgrades on the Evo 10 look no further than an ETS Turbo Kit. Packed with features like high flowing Equal Length ETS Manifold, true Merge Collector, full 3” Downpipe, direct routed Wastegate Dump, low angle turbo outlet, high flow upper intercooler pipe, Tial 44mm Wastegate, and any T3/T4 or Garrett GT series turbos, these kits will get the job done, street or track. Along with great performance, Features such as an exhaust flex, T-Bolt Clamps, 4ply silicone, and braided oil lines, will help make sure that you do not have to use the ETS Life Time Warranty!
Includes:
ETS Mitsubishi Evolution X T3 Twin Scroll Turbo Kit - $4,290.00 (First 5 Customers)
If fast spool is what you need, then an ETS Twin Scroll Turbo Kit is what you’re looking for. A twin scroll turbo kit will typically spool the same turbo 300-500rpm faster than a conventional manifold design. This is accomplished by pairing the correct cylinders in the firing order together, so that the pressure waves arrive at the turbo 180deg apart, making a stronger impact upon the turbine wheel and thus accelerating the turbo faster. Another benefit of opposite cylinder pairing is that when one exhaust valve is open, the exhaust valves of the other cylinder in the pair are closed. 180deg. apart, helping spool the turbo quicker with no loss of top end power.
Includes:
ETS Mitsubishi Evolution X T4 Twin Scroll Turbo Kit - $4580.00 (First 5 Turbo Kit Customers)
Knowing how hard big T4 Turbos are to spool with a 2.0l engine, a twin scroll manifold is desirable for T4 based Turbos such as the GT40r, T04z, and the Gt35r-T4. The Large T4 exhaust sections of these turbos will make big power above 7000rpm, and the twin scroll pressure pulse manifold design helps spool these large turbos sooner than later. Utilizing dual wastegates, the exhaust pressure waves of cylinders 1&4 are kept separate of 2&3 so that they can impact the turbine wheels individually, 180deg. apart, helping spool the turbo quicker with no loss of top end power.
Includes:
Thanks!!
Michael
Features:
- Recirculated Wastegate or Open Dump
- Split Wastegate and Exhaust Design
- Includes 5 studs and 5 nuts for easy install
- Includes Gasket
- Factory o2 sensor location
- Optional wideband bung available
Features:
- Direct Replacement
- J-Pipe O2 Bung (Prevents Check Engine Lights)
- Optional Wideband o2 bung
- Stainless Steel
Features:
- Full Stainless Steel
- 3.0" Diameter
- 2x - 3.0" Straight Through Resonators
- V-band Clamp
- Perfectly Centered Tips
- Stock Mounting Location
- Includes All Hardware
Features:
- <LI dir=ltr>Pressure checked at 35psi. <LI dir=ltr>Bolt on design to retain crash beam. <LI dir=ltr>Fills entire grill with core. <LI dir=ltr>Full mandrel bent 2.5" piping. <LI dir=ltr>Stainless steel t-bolt clamps. <LI dir=ltr>4-ply couplers. <LI dir=ltr>Includes all mounting hardware. <LI dir=ltr>20x12x3.0 Bar & Plate Core - 700hp Direct Replacement <LI dir=ltr>20x12x3.5 Bar & Plate Core - 750hp Direct Replacement +$100
- 20x12x4.0 Bar & Plate Core - 820hp Direct Replacement +$200
features:
- <LI dir=ltr>Pressure checked at 35psi. <LI dir=ltr>Bolt on design to retain crash beam. <LI dir=ltr>Fills entire grill with core. <LI dir=ltr>Stainless steel t-bolt clamps. <LI dir=ltr>4-ply couplers. <LI dir=ltr>Includes all mounting hardware. <LI dir=ltr>20x12x3.0 Bar & Plate Core - 700hp Direct Replacement <LI dir=ltr>20x12x3.5 Bar & Plate Core - 750hp Direct Replacement +$100
Features:
- 2.50" Mandrel Bent Piping.
- Upgradable Upper Intercooler Pipe.
- Upper Intercooler Pipe Bracket
- Lower Intercooler Pipe Bracket
- 4-ply Silicone.
- T-Bolt Clamps.
- Includes all mounting hardware.
- GSR Only (LICP Does not Fit MR)
Features:
- 4-ply Silicone.
- T-Bolt Clamps.
- GSR Only
Features:
- 4-ply Silicone.
- T-Bolt Clamps.
Features:
- 5" KN Filter
- ETS Milled MAF Adapter
- Perfrect Transition From Adapter To MAF
- Blow Off Valve Recirculation Tube
- Mounting Bracket
- BOV Vacuum Line
- All Couplers, Clamps and Hardware.
Includes:
- Turbocharger
- Stainless Steel Downpipe
- Exhaust Manifold
- 44mm TiAL Wastegate
- Wastegate Dump Tube
- Oil Feed and Drain Lines
- Water Feed and Drain Lines
- Turbo Gaskets and Hardware
- Clamps and Couplers
- Includes Everything Needed For A Complete Install
Includes:
- Turbocharger
- Twin Scroll Exhaust Manifold
- Dual 38mm TiAL Wastegate
Includes:
- Turbocharger
Thanks!!
Michael
