Cobb AccessPort & Deatschwerks 800cc Fuel Injectors @ 201 Motorsports
Deatschwerks @ 201 Motorsports
Price: $399 shipped
Originally Posted by 201motorsports.com
Deatschwerks performs flow balancing and quality assurance testing on every set of injectors they produce, ensuring that the end product is top-notch. Deatschwerks injectors are tested and analyzed at over 40 data points on DW's in-house New Age Technologies injector flow bench. Deatshwerks 4B11T injectors are 100% new Denso manufactured units, you can rest assure that you are receiving a top-quality, reliable, well-performing product at a price that is hard to pass up.
Deatschwerks 2008 Evo X fuel injectors are engineered to fit your OEM harness, fuel rail and manifold. Each set of Evo X Deatschwerks injectors is balanced within 2% variation, making them easy to tune. This means better fitment, easier tuning, and increased reliability. Deatschwerks injectors are backed by a comprehensive 12-month warranty.
DeatshWerks fuel injectors for the 08+ Evo X feature drop-in fitments for a simple installation. Since they are made from new Denso manufactured injectors, they will fit directly into the stock or any aftermarket fuel rail. DeatshWerks Evo X fuel injectors will require some sort of fuel management system to work properly such as the Cobb AccessPort.
Cobb Tuning @ 201 Motorsports
Pick up a Cobb AccessPort AND Deatschwerks 800cc Fuel Injectors and we'll sweeten the deal... I'll send you a $50 American Express Gift Card to say thank you for comboing it up
Cobb Tuning AccessPort v2.0 Evolution X
Price: $695 shipped
Flashing the ECU for increased performance is just the start of what the AccessPORT is capable of. Set the AccessPORT to Performance mode to capture 0-60MPH times, ¼ Mile times and Trap Speeds. Switch over to Live Data and choose a gauge to monitor, such as; coolant temperature, intake air temperature, throttle position, intake cam advance, exhaust cam retard, MAF voltage, injector pulse width and many more. Select the integrated Datalogger to record multiple channels of data simultaneously. Or use it as a shift light that flashes the screen when a user defined rpm is reached. Use the Troubleshooting mode to diagnose issues by reading the factory codes and resetting the system once the issues have been resolved.
The AccessPORT can be used to eliminate separation anxiety for those times you are away from your car. Protect your investment when out on the town by quickly loading the Valet map to prevent the engine from revving above 3,200 rpm. Load the Anti-Theft map when you park to make it impossible to start. And in the event the car must be returned to the stock configuration, the AccessPORT can be completely removed and the ECU restored to its factory condition.
The AccessPORT from COBB Tuning is the most comprehensive hand-held ECU flashing, monitoring and managing device available for the Mitsubishi EVO X. Combined with AccessTUNER Pro and AccessTUNER Race software, it provides an unbeatable suite of engine tuning applications backed by our professional engine tuner network.
Satisfy your hunger for more power. Access the Potential of your EVO X today!
EVO X AccessPORT Features:
• Increase horsepower and torque with the touch of a button
• Easy installation requiring no tools or computer skills
• Display vehicle performance with 0-60MPH and 1/4 Mile clocks and Trap Speeds
• Monitor vehicle data such as MAF voltage, coolant temp, throttle position and much more.
• Built in Datalogging capability for multiple data channel recording.
• Troubleshoot by viewing trouble codes and resetting ECU.
• Valet and Anti-Theft modes help prevent abuse and theft
• Upgrade firmware and download calibrated maps over the internet
• Completely and easily uninstallable
Up to the top!
Check out the 2008 Christmas Raffle. Proceeds will be going to Winged Warrior which benefits the kids at Riley Hospital for Children through the Cheer Guild.
Bump it up to the top! Awesome deal here
Great deal!
