Reflective Gold Heat Barrier Foil
Fortune Auto has sourced a thermal barrier from a
local aerospace manufacturer. Our sourced foil is
actually made of 22k gold. capable of reflecting 78%
of all radiant heat with continuous operating temperatures
of 450 degrees centigrade. The material is metalized
polyamide polymer laminated glass cloth with a high
temperature pressure sensitive adhesive.
Typical applications include but are not limited to,
intercooler pipes, intercoolers, intakes, airboxes,
engine covers, coilovers, under trays/floors, seat bottoms,
fire walls and bulkheads. The minimum air gap to heat source
is just 1mm!
Some examples on our demo vehicles
You can order this product here
http://www.fortune-auto.net/apps/web...s/show/1142191
The UICP that we wrapped on the X was about 2 feet.
You could use it on the rear heat shield on the fire wall. It has a very sticky self adhesive....its almost like gold duct tape lol
haha my bad, I mean just one time all the way around! I knew it would have to be custom cut to the pieces im putting it on, but one full wrap around is good right? Would it stick to my ICP with the black material on it? Also if removing will it leave any residue? does it fade?
If its crinkle it will stick but not as well.
It will leave residue similar to duct tape if you remove it and no it will not fade!
