Magnus V5 intake for Evo8 and 9, intock and ready to rock!
*Instock* ready to ship*
Magnus V5 Cast Aluminum Intake Manifold (Mitsubishi Evolution 8 & 9)
Over 10 years ago, Magnus Motorsports released its first Sheet Metal Intake Manifold into the market place and it quickly became the standard within the Mitsubishi Racing community. After almost 2 years in development, we would like to introduce you to the next big thing. The Magnus Motorsports V5 Cast Aluminum EVO Intake Manifold.
We designed this one from a fresh sheet of paper. Out of over a dozen prototypes, endless testing and perfecting, the Magnus Cast Intake Manifold was born. We applied our years of experience from crafting thousands of sheet metal intakes and once again have raised the bar for power and quick response. By applying a unique design and a massive 5L plenum, this cast manifold means big power and big power sooner!
Cast in A356 Aluminum with a wall thickness of 3/16"; the Plenum shape features a varying contoured tapered profile at a volume of 5 liters. The runners themselves are completely revolutionary in their design; featuring an integrated velocity stack that gradually transitions into the head port profile. It was designed entirely against the shape of the original cylinder head port taking advantage the 10° port entry of the EVO head maintaining un-interrupted laminar flow. The Magnus Cast Intake Manifold will work with throttle bodies from stock right up to 100mm and have seen consistent gains from 30 awHp to 52 awHp with varying setups. Transient boost response is exceptional and it can bolt together in a stock location if required while still being able to be used on a full blown race application.
Includes adapter to suit stock or 75mm+ throttle bodies, throttle body gasket, heat barrier gasket to head and supporting hardware!
V5 Cast Aluminum EVO Intake Manifold Features
2 years of research and development
Cast from A356-T6 Aluminum Alloy
High quality casting gives a superior surface finish
Enhanced flow dynamics utilizing CAD Modeling & CFD simulation
Flowbenched and dynamically tested
Dynotested proven up to 50 HP
Ability to flow 100 lb/min (1000 HP) of air at 60PSI while maintaining equal flow distribution
Can be installed in stock location with clearance for original battery (with adaptor)
Stock turbo gains up to 40HP
15 degree entry to the throttle body facilitates intercooler plumbing
Can be configured for 8 injector setup.
Fits factory fuel rail or Magnus high flow fuel rails
5L plenum with contoured velocity stacks molded into the floor for huge top end and minimal turbulence
Magnus Quality and Lifetime warranty
Item Number V5-INTAKE-EVO
Contact your favorite salesman for an amazing price on this item and many others.
