Keep Your Cool at the Track - Agency Power / BWR / Koyo / Mishimoto / Samco
Radiator and hose kits available to keep your Evo cool on or off the track. Tons of mix and match combos available for any budget. Select a radiator, a hose kit, and fans if you need and then PM us for the special EvoM Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
![](http://s3.amazonaws.com/client-storage/11457-8e3f6f14-9a4f-4639-a5e0-399d7ced95b3/jbbanner.gif)
Radiators
Agency Power
The all aluminum radiator features a high pressure radiator cap, aluminum construction, and mounting tabs for a direct OEM replacement. The factory fans and radiator hoses will fit with no modification. As tested the aluminum end tanks and larger core size help keep the temperature down by at least 15F degrees
![](http://jbautosports.com/storage/EvoM_Agency_Power_Radiator.jpg)
BlackWorks Racing
BlackWorks Racing is a great upgrade for your street car, weekend warrior, or full on track car. With our dual core design, cooling your vehicle is not a problem. The BlackWorks Racing radiators will keep your engine cool even under the most extreme high heat racing conditions, or driving in the high heat hellish temperatures in the desert of Arizona.
![](http://jbautosports.com/storage/EvoM_-_Blackworks_Rad.jpg)
Koyo - V Series
Built with a robust 53mm core, the R-Core Series is engineered for the serious performance tuner. Increased capacity means better cooling reserve when you need it. Intended for both circuit and daily use, you may double your coolant capacity and see up to 35% increased performance over your stock radiator.
![](http://jbautosports.com/storage/EvoM_Koyorad_Radiator.jpg)
Mishimoto - Standard
Whether you are a daily driver looking for an upgrade to your OEM radiator, or a racer looking for a dependable quality radiator, we have just what you are looking for! Mishimoto Performance Radiators are 100% brazed aluminum, ensuring a lasting lifetime of efficient cooling.
![](http://jbautosports.com/storage/EvoM_Mishimoto_Radiator.jpg)
Koyo - V Series
Mishimoto - X-Line
Mishimoto has just released the new X-Line of high performance aluminum radiators. Each new X-Line radiator application has 3 rows for a core that is 25% larger than standard radiator applications. The triple core design of the X-Line radiator allows more coolant to flow through, maximizing engine cooling capacity. Each application is designed as a direct OEM replacement, with no customization required for installation.
![](http://jbautosports.com/storage/EvoM_-_Mishimotot_X.jpg)
Radiator Hoses
Agency Power Hoses
Agency Power now offers this 5 ply silicone radiator hose kit for your vehicle. The OEM rubber hose tends to burst under extreme heat and crack over time. These silicone hoses improve flow and are not affected by heat like rubber hoses. Each hose kit includes new clamps for easy installation.
Colors:
Black - Red - Blue
![](http://jbautosports.com/storage/EvoM_Agency_power_Radiator_Hoses.jpg)
Colors:
Black - Red - Blue
Mishimoto Radiator Hose Kit
Mishimoto Radiator Hose Kits are made with a dual layer combining high grade silicone and Dupont Nomex technology to provide efficient heat reduction and increased pressure tolerance.
Colors:
Black - Red - Blue - Orange
![](http://jbautosports.com/storage/EvoM_Mishimoto_Radiator_Hoses.jpg)
Colors:
Mishimoto Radiator Upper Hose Aluminum Kit
Because factory radiator hoses are made of rubber, they are prone to various damage such as swelling or cracks. The Mishimoto Aluminum Upper Radiator Hoses are CNC mandrel bent and made of high-quality T6 temper aluminum. Our aluminum upper radiator hose kits include silicone couplers and t-bolt clamps, with every component backed by an excellent lifetime warranty.
![](http://jbautosports.com/storage/EvoM_-_Mishimoto_Hard_Hose.jpg)
Samco Hose Kit
The Samco Sport Radiator Hose Kits provide a unique opportunity to upgrade your intercooler hoses to a product that is simply un-rivalled worldwide for performance and looks. These direct replacement silicone hoses are available in 7 colors to blend with your engine the way YOU want. Whatever color you choose just remember, you’re fitting the finest radiator hoses that are designed to perform under pressure.
Colors:
Black - Red - Blue - Pink - Yellow - Green - Urban Camo & More
![](http://jbautosports.com/storage/EvoM_Samco_Radiator_Hose.jpg)
Samco Hose Kit
Colors:
Radiator Fans
Mishimoto Slim Fans
The Mishimoto Radiator Fan can be used as an upgrade to the OEM fan for more efficient cooling or fitment issues with aftermarket products. With the Mishimoto Radiator Fan’s slim design, the fan can easily be installed flush against a radiator. Available in 10”, 12” and 14” Applications.
![](http://jbautosports.com/storage/EvoM_Mishimoto_Slim_Fans.jpg)
