Low priced coilovers that DON'T suck.....Eibach coilovers and more!!!!
Sometimes it's amazing to see how cheap coilovers can get. And while the Chinese budget coilovers pack a lot of "features".....the damping is downright terrible and you have hardly any suspension travel to work with. 32 clicks of adjustment doesn't mean much if all 32 clicks suck!
And now here's a known suspension manufacturer with a great reputation with some high quality coilovers at a realistic price you can afford. Available for all levels...street, auto-x, and hardcore track. The dyno plots look GREAT and the spring rates are very good. I have to say I'm impressed with EIBACH!
Feel free to give me a call or PM if you have any questions on why you should trust your suspension to the experts at Eibach in Germany, rather than the cheap crap you find elsewhere at this price point.
Free shipping applies to continental US only.
_______________________________________________
Eibach Pro-Street-S Kit
Height adjustable.
Preset damping rates.
A great set-up for the street, light auto-x and track use. Good ride quality, good handling. No need to worry about playing with different damping settings....just get in and drive!
$1299
free shipping
Eibach Multi-Pro-R1 Kit 1 way damper
Height adjustable.
Single adjustable damping
Custom rates available!
Perfect for street and track enthusiast who wants easy control over damping abilities. Turn it up a little at the track, dial it back down for great street comfort!
$1899
free shipping
Eibach Multi-Pro-R2 Kit 2 way damper
Height adjustable.
Double adjustable damping (seperate bump and rebound adjustments)
Spring rates:
350/440
Awesome track coilover with excellent street capabilities. 2 way damping capability means you have tons of control over the way the shock and car perform. I have seen the shock dyno plots for these and they are awesome!
$2299
free shipping
Some pics of the double adjustable Multi Pro R2 Eibach coilovers with Vorshlag plates:
There hasn't been many decent options in the 1-2k range for EVO in the past. But now there are. These really are a fantastic way to get your EVO X to handle well without sacrificing ride quality and build quality like the cheap crap ones you see all over the place.
And of course, when you buy from GTWorx/Racecomp, you're getting a wealth of suspension knowledge to back you up and help you set the car you want it to handle.
- Andrew
Height adjustable.
$1299
free shipping
Height adjustable.
$1899
free shipping
Height adjustable.
Spring rates:
350/440
$2299
free shipping
- Andrew
Whiteline Roll Center Kit
Lower the car a little more without screwing up suspension geometry. Improve suspension geometry on the stock suspension if you like. Less roll, better camber curve. MORE GRIP.
$190 shipped
Whiteline Rear swaybar
Add front grip, helping to reduce understeer and improve the balance of the car. More overall grip, less roll.
$179 shipped
Whiteline Front swaybar
Add rear grip, reduces rear wheel lift in tight corners, improves turn in. More overall grip, less roll.
$179 shipped
Get both front and rear Whiteline Swaybars for $350 shipped.
Whiteline front control arm bushing
reduces the sloppy rubber bushings that comes OEM. No more dynamic alignment changes while cornering, better control, more grip.
$85 shipped
$190 shipped
$179 shipped
$179 shipped
$85 shipped
Andrew's top 5 things to look for in a coilover
1. A solid US presence from the manufacturer. Can you have them rebuilt quickly and easily without sending them to China, Japan, Germany, Afghanistan, etc.?
2. Spring rates. If a manufacturer puts softer springs in the rear for the EVO....it's a good sign they don't know what they are doing. Seriously big red flags should go up if they do this.
3. Can you get someone on the phone to talk to you about the shock and how to adjust? How about good alignment settings? How about being able to do that on the weekend when you're at the track?
4. Damper travel. You can't soak up mid-corner bumps (or potholes) if you only have an inch of travel before hitting the bumpstops. Lots of coilovers are like this unfortunately. Separate ride height and preload adjustment is nice, but if you have hardly any travel to start with....sorry....you're gonna have some trouble.
5. Valving. The hardest to see and the hardest to evaluate. Shock dyno plots are helpful but can be difficult to understand and not always available. Can the vendor explain how the shock will feel and the reasoning behind the valving?
Remember....a kidney crunching ride is NOT always fast.
Basically, if you want to compete and win....you get JRZ. We share shop space with Bryan of JRZ and get to watch him rebuild and revalve Porsche race shocks all day. The level of service is incredible and we're very fortunate to be able to work with him and learn more about shocks in the process.
Please call for more information. These shocks are custom built to order and are the ULTIMATE in suspension engineering for your EVO.
JRZ RS Double Adjsutable
JRZ RS PRO Double Adjustable
JRZ RACE Single, Double, Triple, and Quadruple adjustable dampers
question about the Eibach R1. can't see clearly from the thumb nail. does it come with front camber plate? helper springs? and most importantly, is there an extension like the Ohlins for the rear damping adjustment?
Andrew,
It seems the KW Variant 2 and the new Eibach single adjustable are very comparable. Which do you prefer between these two and why? If one were to ask for custom spring rates in the Eibach would the valving also be customized to match? What is the cost for custom rates/valving?
Thanks!
Thanks!
