OHLINS are back and better than ever! AST 4100's, JRZ, and Whiteline!
In case you hadn't heard, Ohlins DFV Coilovers are back!
These were improved over the older version with better valving and better build quality.
Includes front camber plates and rear pillowball mounts
dual height adjustable
Rebound adjustable with improved Dual Flow Valve technology for awesome handling and ride quality.
We can work with you to help you dial in ride height, alignment, and damper settings for the street and track.
SALE price of
$3250 SHIPPED
custom rates extra
SALE price of
$3250 SHIPPED
custom rates extra
Finally a new coilover option at a realistic price, that doesn't suck! Awesome euro valving, tons of suspension travel, great USA support, great build quality, and a proven track record (used on the 2009 Redline Time Attack Street champion car).
Monotube, single damping adjustable, with Swift coilover springs.
All sets are CUSTOM....we can work with you on a desired spring rate to match your car and driving style.
$2199 shipped
This price includes custom spring rates and helper springs at all 4 corners.
Avoid the too much rebound, not enough compression damping, poor quality springs, clueless tech support, non-existent suspension travel, coilovers that are so widespread out there....and get something that WORKS!
$2199 shipped
Whiteline Roll Center Kit
Lower the car a little more without screwing up suspension geometry. Improve suspension geometry on the stock suspension if you like. Less roll, better camber curve. MORE GRIP.
$190 shipped
Whiteline Rear swaybar
Add front grip, helping to reduce understeer and improve the balance of the car. More overall grip, less roll.
$191 shipped
Whiteline Front swaybar
Add rear grip, reduces rear wheel lift in tight corners, improves turn in. More overall grip, less roll.
$191 shipped
Get both front and rear Whiteline Swaybars for $379 shipped.
Whiteline front control arm bushing
reduces the sloppy rubber bushings that comes OEM. No more dynamic alignment changes while cornering, better control, more grip.
$85 shipped
$190 shipped
$191 shipped
$191 shipped
$85 shipped
