Coilover Systems - Fortune Auto / Eibach / KW / Stance / KSport / HKS
Old Dec 14, 2011 | 06:20 PM
JBAutosports's Avatar
Tons of good coilover options available for the Evo X. Give us a PM and we can help pick out the right coilover for you, along with offering very competitive pricing. Check our website out for all options, and PM us for the special EvoM Forums price.
AUTHORIZED DEALER FOR OVER 300 PRODUCT LINES
Like us on Facebook for Facebook only specials!
KW Variant 3 Coilovers - We have the best Price around!
KW Variant 3 Coilover System is state-of-the-art technology for the skilled and experienced driver. The separate and independent compression and rebound damping options allow a truly individual driving set-up. These unique systems with the 3 individually adjustable components, allows for adjustment of the compression of the damper in the low-speed range, while the highspeed set-up, so decisive for driving comfort, has been preset by our engineers
Fortune Auto
These are a great option for the budget minded racer. They are rebuild-able right here in the USA and all options offer custom spring rates and valving. Track Tested!
Click the images to learn more:
500 Series
510 Series
DREADNOUGHT© Inverted Coilovers
Eibach Coilovers
These state-of-the-art, race-ready, damping-adjustable coil-overs use a monotube damper design for maximum track performance. Ride height is infinitely adjustable between 0.80” – 2.5” lower than stock, and the dual-spring setup is dialed for maximum cornering performance. Rebound and compression damping are both adjusted-ensuring proper damping balance at any setting.
Multi Pro R1
Multi Pro R2
HKS Coilovers
With the Hipermax III suspension series, the driver gains increased wheel control with improved performance of all vehicle dynamics and increased driver command in all conditions. Hipermax III combines track-quality control with excellent ride and handling characteristics at real-world street speeds. HKS’ all-new Hiper Linear Piston Fluid Channel System damping system creates a positive relationship between piston speed and damping force, making it possible to produce a suspension that provides track-level control and feedback with exceptional ride quality at the same time.
Hipermax III
KSport Coilovers
Ksport Version RR Damper System is built specifically for road racing only. Aggressive rates and valving are chosen for maximum handling and performance with acute reaction and responsiveness. Integrated with 36 levels of dampening adjustment, simultaneous compression and rebound adjustment, lightweight aluminum mounts, and pillow ball upper mounts on some applications.
Kontrol Pro Kit
Key Features
36-way adjustable dampening
Made from high quality 6061 Aluminum with T6 for increased hardness
Compression/Rebound adjustable
Adjustable spring perch for height adjustment
Adjustable body allowing maximum suspension travel
Pillow Ball Top Mount w/ adjustable camber (not available for some models)
Monotube High Pressure Design reduces oil leakage
Electroplated body for protection from corrosion and rust
One Year Limited Warranty
Click the image to learn more:
Kontrol Pro Evo X
Stance Coilovers
The GR+ is the Stance flagship line. It features 15-way damping adjustable monotube shocks, which allows the driver to fine-tune the handling and ride. A separate lower bracket allows the ride height to be adjusted without sacrificing stroke. Spherical bearings are used to give the driver greater feedback. Inverted monotube shocks are utilized on strut types for greater rigidity and heat dissipation. Camber adjustable upper mounts are used on strut types.
Stance GR+
Moton
AST
Cusco
Tein
Don't see something listed? PM us!! We may just be in the giving mood and hook you up!
This is old news for most, but for those who have not heard of Whiteline, the brand graces a number performance suspension components that work hard to deliver real results and performance outcomes for vehicles and motorists the world over.
Whiteline’s primary focus was initially delivering ‘bang for your buck’ handling gains from the simplicity of an anti sway bar. But over the years, the expertise, the knowledge, the reputation and the products have grown since progressed to include additional offerings such as the range of infamous anti lift/caster kits, roll centre adjuster kits, adjustable control arms, camber kits, strut and chassis bracing.
Adjustable Front or Rear 27mm Sway Bar
The Whiteline Flat Out EVO X Rear 3 POINT ADJUSTABLE solid steel Sway Bar 27mm diameter is a great addition to the Evo to help conquer mid-corner understeer. This kit includes high performance polyurethane sway bar bushings.
End Links Front (KLC39) or Rear Heavy Duty (KLC174)
Bump Steer Kit
Anti Lift Kit
Rear Camber/Toe Correction Arms
Lateral Lock Kits
Rear Heavy Duty Mounts(Special Order) Comes with new bushings as well.
PM us for the special EvoX Forums price or check out through our website.
Old Dec 15, 2011 | 03:28 AM
Koa257's Avatar
pm me the best stance coils for dd comfort and weekend warrior status driving thanks
Old Dec 15, 2011 | 02:48 PM
Jade@Ksport's Avatar
What we offer here at Ksport, hope you all enjoy!
http://www.youtube.com/watch?v=n5o9K2KvvPw
Old Dec 15, 2011 | 08:40 PM
Krotondo's Avatar
pm sent
Old Dec 17, 2011 | 11:57 AM
Pm's replied
Old Dec 20, 2011 | 09:55 AM
bump
Old Dec 22, 2011 | 06:34 AM
Thank you for the Orders!
Old Dec 27, 2011 | 09:55 AM
Hope everyone had a great Christmas!
Old Dec 27, 2011 | 05:05 PM
Hope everyone had a great weekend excited for the new year we appreciate the love and support!
-Jade
Old Dec 30, 2011 | 06:35 AM
Have a safe and happy New Years everyone!
Old Jan 2, 2012 | 09:02 AM
Back from the New Year! Let us know if you have any questions.
Old Jan 5, 2012 | 12:35 PM
Wicked price on KW V3's right now!
Old Jan 5, 2012 | 07:39 PM
EBEVOIX's Avatar
Price on KW V3's please.
Old Jan 6, 2012 | 10:07 PM
Pm sent boss!
Old Jan 11, 2012 | 06:19 AM
Thanks for the orders guys!
