Tein Coilovers/ Springs/ EDFC- Need Anything Tein related? Come on in!
Looking to finally pull the trigger on that set of Tein coilovers you've always had your eye on? Want to get rid of some wheel gap on a budget with a set of quality springs? Now is the best time to get the Tein suspension you need for your Evo! Let me know what you need and I'll shoot you back our best pricing. We are new to EvoM, so the bosses want to throw some super deals out here to get our name around the Evo community.
As of right now, these are all in stock and ready to ship same-day. We don't need to sell you on a set of Tein coilovers, if you have an Evo, you want these! Its just a matter of which ones to get based on how you use your car and how extreme of a setup you are looking for. Suspension is not something you want to cheap out on and use poor quality components with.
PM me or give us a call for pricing. If you call, be sure to tell us your username so we can verify that you are a member and qualify for the EvoM special.
Tein Basic Coilovers-
Type BASIC Damper; Not EDFC Compatiable
Ride Height Adj Range (F): -1.3~-2.3in (-33~-57.25mm)
Spring Rate Adj Range (F): +1.0~-1.0lbs/in (56~-56kgf/mm)
Ride Height Adj Range (R): -0.2~-1.5in (-5~-37.2mm)
Ride Height Adj Range (F): -1.3~-2.3in (-33~-59mm)
Spring Rate (R): 336lbs/in (6kgf/mm)
Uppermount: OEM Uppermount
Spring Rate (F): 392lbs/in (7kgf/mm)
Ride Height Adj Range (R): -0.1~-1.6in (-2~-39.5mm)
Spring Rate Adj Range (R): +1.0~-1.0lbs/in (56~-56kgf/mm)
Ride Height Adj Range (F): -1.3~-2.6in (-34~-66.75mm)
Ride Height Adj Range (R): -0.3~-1.7in (-8~-42.85mm)
TEIN Dampers - Type Basic: TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price. The Basic damper includes 4 springs and 4 shocks. Compared to the "sleeve type" coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force.
*Features*
* High performance and cost effective
* Ride Height adjustable
* New paint coating for rust prevention
* Pillow ball mounts are optional (on certain applications)
* Exclusive design for USA vehicle specifications
* Available for overhaul
Tein Super Street Coilovers-
Super Street Damper; For EDFC use EDK05-10120 (Motor)
Ride Height Adj Range (F): -1.7~-2.6in (-43~-67mm)
Ride Height Adj Range (R): -0.3~-1.6in (-8~-40.07mm)
Spring Rate Adj Range (F): +2.0~-2.0lbs/in (112~-112kgf/mm)
Spring Rate Adj Range (R): +2.0~-2.0lbs/in (112~-112kgf/mm)
Ride Height Adj Range (R): -0.1~-1.4in (-2~-36.5mm)
Ride Height Adj Range (F): -1.3~-2.5in (-34~-64.25mm)
Ride Height Adj Range (R): -0.4~-1.7in (-9~-43.24mm)
Ride Height Adj Range (F): -1.3~-2.2in (-33~-55.35mm)
TEIN Dampers - Super Street: TEIN has developed advanced technology to design the shell case and stroke to bring out the full potential of your vehicle.
These features of the TEIN Super Street Damper kit were designed with greater performance to satisfy all your driving demands. This high performance damper can be used for weekend racing and/or daily driving.
The discomfort caused by uneven roads or bumps are eliminated on daily street use. For race use, the ride height adjustable system enables you to adjust ride height and 16 levels of damping force.
In other words, you can set your vehicle to meet all situations!
*Features*
* High performance and cost effective.
* 16 levels of damping force adjustment (compression and rebound together).
* Ride height adjustable.
* New paint coating for rust prevention.
* Pillow ball mounts are optional (on certain applications).
* Exclusive design for USA vehicle specifications (only available for the U.S.A Market).
* Available for overhaul.
Tein Mono Flex Coilovers-
Mono Flex Damper; For EDFC use EDK05-12120 (Motor)
Ride Height Adj Range (R): 0.9~-2.7in (22~-68mm)
Ride Height Adj Range (F): -0.6~-2.4in (-15~-62mm)
Spring Rate (F): 783lbs/in (14kgf/mm)
Ride Height Adj Range (F): -0.4~-2.9in (-11~-73mm)
Ride Height Adj Range (R): 0.6~-2.9in (14~-74.4mm)
Uppermount: Pillowball Uppermount
Ride Height Adj Range (F): -0.6~-2.5in (-14~-64mm)
Ride Height Adj Range (R): 0.6~-2.7in (14~-69.7mm)
Ride Height Adj Range (F): -0.9~-2.9in (-24~-74mm)
Ride Height Adj Range (R): 0.6~-2.5in (14~-62.4mm)
Spring Rate (R): 559lbs/in (10kgf/mm)
TEIN Dampers - Mono Flex: TEIN MonoFlex Dampers - The Next Level of Performance Coilovers
Newly designed and developed for those core drivers seeking the ultimate in street and track performance. Best suited for those drivers whose priority is a high grip level for touge, circuit, and other tarmac driving. Offers both direct feel and a high level of tune-ability that will satisfy the needs of aggressive street and track use. Developed to be used with High Performance Tires. Mono FLEX was tested with high grip tires and/ or larger diameter wheels in mind, and are recommended to bring out the full potential of this aggressive suspension system.
*Features*
* Mono-tube internal damper design
* Full-length ride height adjustment system
* 16-level damping force adjustment feature (combined comp./rebound adjustment)
* Newly developed M.S.V. (Micro Speed Valve)
* EDFC compatible for easy in-car damping force adjustment!!
Tein Super Racing Coilovers-
Super Racing Damper; For EDFC use EDK05-12140 & EDK05-12120 (Motor) & EDK06-K4474(Strut Kit)
Spring Rate (F): 671lbs/in (12kgf/mm)
Ride Height Adj Range (F): -0.8~-3in (-20~-76mm)
Ride Height Adj Range (F): -0.9~-2.6in (-22~-67mm)
Ride Height Adj Range (R): 0.2~-3.3in (6~-83mm)
Ride Height Adj Range (F): -1.3~-3in (-32~-77mm)
Ride Height Adj Range (R): -0.1~-3.3in (-2~-84.26mm)
Ride Height Adj Range (R): 0~-3in (-1~-76.52mm)
Ride Height Adj Range (R): -0.1~-3.5in (-2~-89.32mm)
Ride Height Adj Range (F): -0.9~-2.6in (-22~-65mm)
TEIN Dampers - Super Racing: The Street Version Sports Shock Absorber, Inherited All the DNA of 'Type N1'. Unlimited Setting Capabilities!
*Features*
* Top-of-the-Line Ready-for-Competition Sports Shock Absorber for serious users
* Mono-Tube Shell Case Structure
* Full-Length Ride Height Adjustment System
* Separate Compression and Rebound Damping Force Adjustmentbr
* EDFC compatible, for easier in-car adjustment (2 sets of EDFC kit required)
Tein EDFC-
TEIN EDFC: The EDFC (Electronic Damping Force Controller) makes it possible for the driver to control the damping force at the touch of a button while in the drivers seat. This is accomplished by controlling stepping motors installed on each shock absorber. Because the damping force can be controlled with such ease, the driver can adjust the suspension to suit all road/track conditions. Thus allowing the driver to fully enjoy the driving experience.
*EDFC Control Unit*
* Compact 1/4 DIN size
* 3 Presets for Quick Adjustments
* Separately adjustable for front and rear
* Ability to use switch between 16 and 32 way adjustment
* Illumination for ease of use at night
* Variable Illumination control
* Variable Volume control
*EDFC Motor Kit and Wiring Harness*
* Sealed rubber motor cover for improved protection
* Decreased stepping motor size for use on more applications
* Complete harness with female/ male connectors
* Extended wiring harness for ease of installation
*EDFC Strut Kit*
* Uses a stopper bracket to eliminate tangling of EDFC wiring on strut type front suspensions.
* Tangling is caused by the strut suspension design which rotates when turning the wheels. Without the Strut kit the EDFC wires will become tangled and may break.
Tein EDFC Motor Kit M10 / M12 - EDK05-10120
Tein EDFC Motor Kit M12 / M12 - EDK05-12120
Tein EDFC Motor Kit M12 / M14 - EDK05-12140
Tein EDFC Strut Kit - EDK06-K4474
Tein Pillowball Upper Mounts-
(For Basic and Super Street Coilovers)
TEIN Pillowball Upper Mount : TEIN's pillow ball (spherical bearing) upper mount is designed for each individual model of the vehicle. By remaining the positioning design of upper spring and shock absorber close to manufacture's standards, TEIN's pillow ball upper mount keeps height change to the minimum and maintains the stroke center.
*The rubber bushing is replaced with a pillow ball which eliminates the load input compliance, reduces the change of alignment to improve the grip of the tire
*Ultra duralumin A2017S-T4 (aircraft material) is used for upper seats and adjusting plates with anodized aluminum to have maximum strength and durability
*For the Mcpherson strut suspension(only for front) models, the camber angle is adjustable. This creates wide varieties of different suspension settings according to the road and tire conditions
*High tension material S45C is used for serration bolts. As it is already inserted with high press, installation time has been completely reduced. With the original long bolt design, it can be easily mounted and gives enough thread for the strut tower bar to be fitted
*Fronts and rears sold separately, both in stock*
Tein S-Tech Springs-
Ride Height (F): -1.8in (-46mm)
Ride Height (F): -2in (-51mm)
Spring Rate (F): 213lbs/in (3.8kgf/mm)
Ride Height (R): -0.9in (-22mm)
Ride Height (R): -1.1in (-29mm)
Spring Rate (R): 291lbs/in (5.2kgf/mm)
Spring Rate (F): 212lbs/in (3.8kgf/mm)
TEIN Springs - S-Tech: TEIN S.TECH Spring is an excellent step towards suspension tuning.
They offer approximately a 1.5 inch drop for a more aggressive appearance. Comes with a 1 year limited warranty.
Spring length is guaranteed not to sag more than 5mm and to be clear of any manufacture defects.
*Features*
* One year limited warranty
* High-grade material adapted to improve guaranteed satisfaction
* Rubber spring protector sheet to prevent noise (most applications)
Tein H-Tech Springs-
Ride Height (R): -0.3in (-7mm)
Spring Rate (F): 196lbs/in (3.5kgf/mm)
Spring Rate (R): 269lbs/in (4.8kgf/mm)
Ride Height (F): -1.4in (-36mm)
Ride Height (R): -0.6in (-14mm)
Ride Height (F): -1.2in (-31mm)
Spring Rate (R): 268lbs/in (4.8kgf/mm)
TEIN Springs - H-Tech: High Tech is made from a new material called "Vanadium" which is much lighter then other spring and increases flexibility.
*Features*
* All spring are designed specifically to fit each car for maximum performance
* About a 1 inch drop for a more attractive appearance
* Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet (available for most models)
PM me for all pricing inquiries, or give us a call at 631-223-8090 with your EvoM username to take advantage of this special.
*EDFC Control Unit*
*EDFC Strut Kit*
*Features*
*Features*
LSD Motorsports
Vendor Classifieds
10
May 18, 2017 04:19 PM
FS[MidWest]: Megan Racing track series coilovers good shape
Hoojan
Jul 14, 2016 03:36 PM
FS[Northeast]: Eibach Pro Kit Lowering Springs
BeyondLimitsEvo
Oct 25, 2015 12:10 PM
Smike
33
Jun 7, 2014 03:47 PM
AJW Performance
94
May 23, 2012 10:59 PM
adjustment, bearing, coilovers, compression, edfc, electronic, evom, needed, racing, rebound, set, springs, strut, tein, valve
