ETS - Now Offering Forced Performance HTA Turbo Kits - Super Value + Equal Length!
#41
Here is a picture of the wastegate dump on an older kit. The new design is slightly longer to keep exhaust gas well away from the starter but the dump routing is the same
It would be $175 to add a Tial 44mm and set up the kit with V-band connections at both ends to accommodate that wastegate
Tom
Tom
#44
The Tial 38mm gates do a great job of steadily controlling boost down to around 15psi on EVOs. You'd only need a larger gate for a lower boost setting (more exhaust volume evacuated pre-turbine for less boost pressure) which we don't see as very practical in a big turbo application. We're all about maximizing bang for your performance buck so unless it's necessary for proper function/performance we won't include and charge for it
Tom
