what injectors to get ?
I have a 57 trim kit waitingto be put on, im going to be running 93oct with an aquamist 100% meth kit... im looking for right around 500whp
stock ecu, bc 272 cams, arp head/rod bolts, ebay clone fmic for now until i end up getting your 3.5 fmic,, walbro 255, br short route uicp, rsr tbe, test pipe, aem uego wideband
what injectors?? 780s 880s"?? more or less
Lot of people are running 1000's on stock ECU--- not a problem if you have a competent tuner.
I'd run 880's for your setup though. 780's would be sufficient, but I'd give some headroom incase you go bigger in the future.
I'd suggest 1000cc injectors as well because they don't cost any more than the smaller ones and will prevent you having to upgrade your upgrade again later. Those would assure that you'll have plenty of fuel to max out that turbocharger on race gas and get a long way on E85 if your plans ever deviate from pump+meth.
Tom
Tom
1SlowRS
Apr 27, 2016 12:06 AM
ToMuchBoost
May 5, 2008 01:01 AM
