!ETS 3inch DP Back with RES installed!!!!!!!!!!! WOW
#31
you will def thro a code if you dont have a fouler in it... but i heard my friends without a res and thats y i got it with the res.. not to mention he has a res waiting to get put on.. sounds better with one
#33
HA YESS it is..
its accually called a spark plug fouler.. but you drill the hole larger and it is basically an extension you screw into the exhaust then the o2 sensor into that and it takes the o2 sensor out of the exhaust stream so it cant get an accuarate reading.. so u dont thro codes
#44
The ets exhuast sounds great but i'm sorry to break to you nothing,nothing,sounds like the buschur racing bullet tbe with off pipe.When the turbo spools up and kicks in it (sounds like the car is throwing up)!!!!!!
