New Evolution X Products!! T3/T4/TS Top Mount Turbo Kits! Stock Turbo Manifold!!
#32
Peak Boost Top Mount
ETS Top Mount
I'm not sure if you are trying to show off your turbo kit, or if you are offended by our turbo kit. There are only a couple ways to build a top mount turbo kit. We could have built our manifold to locate the turbo in the same location (this would have made it way easier to build a down pipe) But due to how the 8/9 cam angle sensor responded to heat we wanted to move the turbo as far over to the passenger side as possible and away from the cam angle sensor. The manifold we build also allows up to a 40R. I'm not sure how big off a turbo you can run.
If you want you can post up a pic of your manifold? I'm sure there is going to be some difference between ours and yours, since we have never seen yours.
Thanks!!
Michael
#41
Thanks!
Michael
