A Look Behind The ETS Testing Scene!
Here is a look into some of the testing that goes on behind the scene at ETS. This testing is for our 335i BMW Intercooler Upgrade.
Test Data
Stock Intercooler (Bad Plugs and Stage 1 Tune)
ETS Intercooler (Bad Plugs and Stage 1 Tune)
4th Gear Pull - ETS vs Stock (Bad Plugs and Stage 1 Tune)
Stock IC vs ETS Gear Comparison
Start Log File (Same Outlet Temps)
Start Pull - The stock intercooler will start to heat up at idle.
Middle Pull - 1:00 minute into the pull the outlet temps have a 37.8 degree difference.
End Pull - 1:05 into the pull the outlet temps have a difference of 59.4 degree.
1st Through 4th Gear Pull - Stock VS ETS Intercooler (Bad Plugs w/ Stage 1)
Top of 1st Gear Pull
Top of 2nd Gear Pull
Top of 3rd Gear Pull
Top of 4th Gear Pull
15 Sec. after pull.
30 Sec. after pull. - The car still has a 42 degree temp difference between the two, I can't even imagine what the temps are like after a few pulls.
It's amazing what a good set of plugs can do. We didni't have time to go through all the tests again with good plugs, but you can get a good idea of how good this intercooler works. All tests were done on an Automatic 335i.
Product Pictures
Stock vs ETS (Direct Bolt On)
Available In Blue, Black, Red and Gold Anodizing
Installed Picture (No Cutting Required)
Thanks,
Michael
Test Data
15 Sec. after pull.
Product Pictures
Thanks,
Michael
Nice...anybody notice that a 335i is putting down almost 400whp with only about 2 mods through an automatic They are monsters on the highway...stock turbo evo gonna need E85 to keep up with them.
Btw you guys are gonna swarm their market because the other kits out their for the 335i are insanely expensive. Gonna see 335i hitting up the track with ETS stickers soon...yessir
Test Data
15 Sec. after pull.
Product Pictures
Thanks,
Michael
Test Data
15 Sec. after pull.
Product Pictures
Thanks,
Michael
ETS Doing it right!
ETS Michael
59
Nov 18, 2010 05:12 PM
raytrix
Nov 8, 2010 08:54 PM
ETS Michael
ExtremeTurboSystems.com – WA
16
Mar 27, 2009 09:12 AM
