How reliable are twin-clutch transmissions (DSG, SST)?
my friends a3 is trapping 115-117. its been running this time for about 40k now... the car currently has 65 on it and has had 0 problems.. it has the apr fmic, ehaust and chip and some nitrous. The tuning companies say its good for 320-330whp before it has to be upgraded which is around 2k for a higher clamp.
Hopefully this tranny will be the end to mitsu's #1 problem
****ty tranny!
With this in mind our cars only problem should be breaking axles from hard launchs =-)
Cheers
****ty tranny!
Cheers
Kind of off topic, but how would you even go about launching the Semi-auto?
And also, why would everyone pick this SST over the standard manual? A sports car isn't really a sports car without a manual. (Don't tell me it shifts quicker than any man, because that's not the point. The point is, the manual tranny seperates a sports car from others.) The SST takes skill away from the driver.
Mitsu has included SST so
the lady of the house would have less reason to reject
the man's decision to buy the Evo, cause the lady would also be
able to drive the Evo. That's not saying more ladies would not be outright Evo buyers than before.
at the end of the day, its just an overhyped automatic.
It's a twin clutch sequential manual transmission that shifts faster than any human on earth. Gear changes are initiated via paddle shifters, which cause the computer to shifts gears. So, it's a semi manual/semi automatic transmission. If you are lazy you also have the option in putting it in fully automatic mode where you just press the gas and go.
![lol](https://www.evolutionm.net/forums/images/smilies/lol.gif)
The vw's have a launch button which can be preset for whatever rpm you want using vag com.
Racing isn't looking the coolest while shifting. Racing is being the fastest. An automatic tranny isn't faster than manual unless ur talking about those crazy expensive 7-9 second cars. Forget about them.
The way this gearbox works is the gears are lined up 135 on one side and 246 on another
while ur in first gear the one clutch is clamped on it while the other sits freely on 2nd. As soon as its time to shift to 2nd no change has to be made except to let go of one gear and grab the next.
Then the first gear is replaced with 3rd gear where the clutch is. The gear change is actually made while ur on the gas instead of while ur off the gas.
you can basically think of it as shifting faster than u just pushing the clutch in. It really is an amazing transmission and im sure it going to be beefed up. If you notice mitsubishi always over designs the evo's. Our motors and trannys are handling 600whp even thogh we're making 250 stock.... I doubt theyre going to put a tranny in that can only handle say 350bhp when stock we'll be making 300-325 most likely.
This is just a step in the right direction. With this tranny there cant be any human error so our cars will just be that much faster and consistent.
Cheers!
While that sucks for him, there are two reasons why it's not worrying to me as a potential EVO SST buyer:
1. VW has been having serious quality problems for years.
2. There's always a lemon in every bunch. If we all listened to every story from someone about how unreliable his/her car has been, no one would every buy ANY car.
Mitsubishi is not VW, and SST is not DSG. Even if you assume that VW is having problems with all of their DSG transmissions (which I think is unlikely), this does not mean that twin-shaft sequential manual transmissions in general are fundamentally unreliable, and therefore, there is no reason to assume based on this experience, that the EVO SST tranny will be unreliable.
I'm sure the tranny will handle some power, but how reliable and bulletproof will it be? Let's just say that the current evo's do not have by any means the best transmissions, eating synchro after synchro. Even in stock power level form. And let's not even talk about the clutches.
That's cool for the launch control.
And if what you say is true, slowsportsedan, how does the car anticipate downshifts?
Vigo, the Bugatti is not a sports car... It's a supercar. You won't see many of those competing on the WRC or at the strip or whatever. I understand that the SST shifts quick, but it still rely's on human input to get desired results. I don't care how quick a computer will shift my car if it has no idea when I need to downshift going into the turn, or need to skip a gear for some odd reason. The SST is not foolproof and I don't think it alone will help track times over a really good manual tranny driver. It's basically designed for poorly skilled drivers. Plain and simple. I don't want a car that my gf can take for a stroll whenever she pleases. And I know for a fact, that you're not ever gonna crack a sub 1.8 60' on a stock SST. It simply won't allow you to put the tranny in danger. Too many safegaurds. This is Mitsu's **** poor answer to synchro and clutch issues.
