Evo X MR Sportronic!!!
"In Normal mode, the TC-SST behaves no differently than a conventional automatic, which is a powerful argument when you're stuck on the freeway during rush hour. " (see http://64.233.169.104/search?q=cache...lnk&cd=7&gl=us )
It's not an automatic for the following reasons: It has no torque coverter and isn't controlled with a series of bands and planetary gears
It's referred to as an automated manual because, internally, the transmission is nearly identical to a traditional manual - meshed gears lined up on input/output shafts. The only difference is the automated clutch.
I haven't seen Mitsubishi, other than some uninformated salespeople, use the term sportronic. I've only seen them refer to it as a Sport Shift Transmission. Again, sportronic would be a confusing term because that's usually refers to tradional automatics (torque converter and bands) with a manual shift feature for driver pleasure.
Here's a handy guide to this type of transmission and how it differs from others - http://auto.howstuffworks.com/dual-c...ansmission.htm
I'll resist closing this thread for the moment, in hopes that you'll understand what we're talking about, but this info really is all over the forums and has been discussed thoroughly for well over a year.
There is high probability that a member can miss a previous thread with a similar topic when he/she searches (there are pages of threads and there are sometimes different terminologies for the same construct, so it can easily happen). So, if someone doesn't do the "perfect search", then they get called a make believe word? How childish is that? GROW UP!
I never said that the Evo X MR was traditional automatic, I was commenting on the “sporttronic” aspect of it. And yes, the TC – SST stands for Twin Clutch – Sportronic Shift Transmission. If you don’t think “S” in SST stands for “Sporttronic” then take it up with Mitsubishi or MotorTrend (see their article below) http://72.14.205.104/search?q=cache:...lnk&cd=9&gl=us
And here's another link, http://64.233.169.104/search?q=cache...lnk&cd=7&gl=us
The attack was on the words "sportronic" and "automatic," but these terms were coined in articles (see above), so read carefully and leave me alone!
