Hear-Ye Hear-Ye! UTEC Firmware v1.7 is online...
Old Sep 25, 2004, 07:18 AM
  #46
Imprezd's Avatar
Originally Posted by 4G63 T
Alright ... went to the track tonight here's results
ET 1/4 12.68
Reactn time .7362
Speed 1/4 mile 107.97
60 ft. 1.7621 330 ft. 5.2013
1/8 mile 8.0924
Mods: Injen intake, Turboxs catback, helix Dp, Random tech high flow cat, Perrin fuel rail, 660 Denso , 255 walboro, AMS pulley, Utec, street tuned by turbo xs, Hks 264/272.
I need assesment above result since im neophyte in Drag racing.
Thanks.
For a road tune that's pretty bad *** man. You should schedule a dyno tune with race gas. Your setup should go 11's on race easy onces tuned.
Good Job though.
Thanks,
Jermaine@turboxs.com
Old Sep 25, 2004, 10:17 AM
  #47
e8
e8's Avatar
Jermaine-
Will you guys every produce an "oxygen challenged" map(like hte WRX) for us using 91 octane?
Old Sep 25, 2004, 10:41 AM
  #48
justrick's Avatar
helluva product
ive been tuning with new software, i have to say its easy as hell, the OLF is awesome because i can setup to go open loop and start richening up at at a lower point like the stock ecu does...
im not the best driver in the world. but the car makes up for it..
12.6 at 113 60ft 1.98 reaction .83---
93 oct at 22 psi --11.8 afr on at 30 minute map setup with only 17 degrees total timing.
the ecu to utec crossover is pretty smooth now..
my cams and gears will be here next week, should be fun...11's are just around the corner, and the turbo and engine arent even working hard yet...
UTEC works.
Old Sep 25, 2004, 10:50 AM
  #49
MalibuJack's Avatar
Yeah, I'm so glad the Firmware is finally released, I can finally go through and do some of the modifications I had been putting off, like my fuel pump and blowthrough MAF.. some of the other stuff won't get done until my new engine is done. But at least tuning and airflow are no longer issues..
Old Oct 5, 2004, 09:04 AM
  #50
Ad-Rok's Avatar
Walboro 255 pump...
Jack / Jermaine:
I have a Walboro pump I've been waiting to install as well...will I need to adjust any parameters or settings on my UTEC for having a new pump in there? I don't have new injectors or anything else, just got the pump because I heard it was better for safety reasons running higher than stock boost...
Cheers,
Adam
Old Oct 5, 2004, 09:13 AM
  #51
Imprezd's Avatar
You should be fine, if not that's the joy of the utec it's user tunable.
Thanks,
Slewisr1
Oct 20, 2016 08:28 PM
05evo8gsr
Jan 23, 2016 10:26 AM
mci2727
Lancer How Tos / Installations
Apr 23, 2011 04:07 PM
phyzfer
Mar 24, 2011 05:17 PM
Quick Reply: Hear-Ye Hear-Ye! UTEC Firmware v1.7 is online...
