Autronic vs. AEM
Old Sep 8, 2005, 12:14 AM
EFIxMR's Avatar
You can build a custom adapter like i did for mine, if you really want to run a Motec M800
Old Sep 8, 2005, 01:21 AM
Sean@Iveytune's Avatar
Another excellent option.
Sean
Old Sep 8, 2005, 09:37 PM
fre
fre's Avatar
Well my AEM works like a champ. Not much tuning done and I already run as fast as I use to and the driveability is waaay better. I also had a friend that was experienced help me get started though. From here I can tweak it no problem.
Old Sep 12, 2005, 12:34 PM
GOT EVO's Avatar
the Evo PNP comes with everyhing you need to install and opperate Autronic. the Air temp sensor comes with the board and the map sensor is internal. autronic can control the stock boost solenoid aswell. thats what i use right now.... most of you allready have a boost controller anyways so you could use that too. the only other thing that you should buy is a wideband. $299 shipped for a PLX M-300 Also $0.50 for a 9k resistor & 1k resistor, that will make the PLX ground voltage the same as the $1600 Autronic analyzer. I got my autronic PnP and installed for under $2000 and I had allready bought a PLX wideband. when you first look at the program it will look weird to you because your fuel map works off of volumetric efficency, but once you understand how to use its the easiest thing in the world to use. My girlfriend can even tune my evo, it's that easy....
b16_rex
May 6, 2012 07:11 AM
MayhemSi
54
Jan 19, 2008 06:38 AM
EvO6-RS2
13
Mar 8, 2007 05:32 AM
Ackerson
19
Feb 14, 2007 10:30 PM
HuskerEVO
Jun 25, 2005 08:54 PM
Quick Reply: Autronic vs. AEM
