evo 7 power fc on evo 8? please read
i found a evo 7 power fc and the seller says it will work with some modifications if i install on the evo 8. ive searched everywhere and cannot find info on this. anyone know if it will work? or tried it? what is the difference?
also, what is the part number for the evo 8 edition pfc?
whats the number for the 7?
thanks.
thanks.
Did you buy it yet, I just bought an Evo 8 Power FC to put in my Evo MR.....If it doesn't work for me I can sell it to you. Write me back if you are interested talalhz@yahoo.com
lol, Evo Power FCs do not work on any car other then the car it was made for. In the case of similar models you can sometimes re-pin the harness to accept same engine from a different year.
-James
-James
Power FC from JDM Evo 7 on a USDM Evo 8 Mr
Hi all.
Bringing this tread back from the dead instead of starting a new tread.
I have a Box marked PFC CT9A7 020. I belive it was built for a JDM Evo 7. I have a USDM Evo 8 MR, and would like to use the Power FC in this car.
Both are 4 Connector ECU, and it looks like it plugs right in.
Fuel relay: I read about this - What specifically do I need to do? Rewire, or do I have to install a new relay?
Manual in English - Is there any manual for PFC in English online?
5-pin Connector on side of PFC - Does anyone have a wiring pin out for the flat 5 pin Connector on the side? I think this is for the aux boost Control??
Boost Control - Will the PFC use the factory solenoid for boost controll? If yes, will it run just on/off, or can it be used "duty cycle" to Control boost more "dynamic"?
Last - If anyone has a Controller for this PFC, I am in the market. I did not get any with the PFC.
94AWDcoupe
Jan 4, 2017 09:05 PM
gavi101
Dec 12, 2013 02:37 PM
