For anyone considering the AEM vs. Autronic...
Originally Posted by DynoFlash
Actually - by the time I was done with my Autronic experiments I had it fairly well figured out - well enough to set some track records with it. I speak from experience with both products when I say that I greatly prefer the AEM unit - IMHO it is the best choice. And - I dont sell any of them.
I just recently installed autronic. went from stock Ecu to driving around on autronic in literally 30 mins. the system is easy to use and the only tuneing i have done prior to this is V-AFC's from my honda days.
Originally Posted by MayhemSi
I'm not even bothering with the sm4 box.. there really isn't in it that you need (unless you are scared and need "knock control")
Okay, i've had an autronic for about 3 months now, and it's definely a good emanage system. anyway, as most of you know it doesn't come with a KNOCK SENSOR. so i was wondering what you guys were doing about knock detection. I would greatly appreciate some suggestions as to what i should get to detect knock.
thanks
thanks
we do nothing about it. just get a good wideband. I suggest PLX. dont go over 20 deg. timeing at WOT (I run 18), 20 psi on pumpgas, and keep the AFR in the 11's and you wont have a problem.
Originally Posted by TampaTSi
are there any systems out there for evos that use the stock ecu/sensors (and hence the stock fuel and timing maps) but that allow users to modify the WOT fuel/timing curves?
It's called ECUplus (or ECU+)
The version 2 is coming out at the end of July. You should check out the features. Knock Sensors, Analog inputs, O2 sim, ignition timing, fueling, Idling Stablizer, the works.
Dan at MachV is going to have the first 4 units but I think they may be spoken for.
I got Dynoflash because of the neccessity and Al made me tons of power (Thanks AL. But I still want to enventually tune the car myself and this ECU+ unit is hard to match with any other system avail on the market.
Originally Posted by KFive
We have now 2 local guys running the autronic and it seems like a great system! One of them is running 592hp! I'll definetly be looking into one soon.
thanks
thanks
Originally Posted by sayanara
I actually got to see one of the older smc units in action two nights ago, and it seems very simple to use. I'm switching to the new sm4 autronic box, in about 6 weeks. Can't wait.
