A christmas Gift.. UTEC Digital Dashboard
Originally Posted by MalibuJack
the command line (Look at the batch file that is included) it has it set for 1, but change it to 4 and run the batch file.. If not, look at how the command line is formatted, and create a shortcut for it.
--Josh
Ok Jack I got this one... Ok Josh simply right click on the batch file... (its labeled UTEC) right click and select EDIT. 3rd line from the bottom you'll see PORT=1 change that simply to your port and close saving changes.. thats all there is to it..
not bad for a psych major huh Jack? haha btw AWESOME DUDE!! tried it tonight love it alot better than the standard Hyperterminal Dash!!! Dude keep up the good work!! I definitely am interested in future installments.. and THANKS FOR AN AWESOME CHRISTMAS PRESENT!!!
Thanks! I'm glad someone is using it and enjoying it.. BTW, the log files turn up in whatever directory you launched the app from.. Never bothered to do anything complex with that.
This app was originally designed to run on an In-Car PC with a 640x480 or 800x600 screen..
Eventually I'll get around to porting this to Visual Basic .NET and adding a ton of new features, but I really like the simplicity of this..
I guess you like the fact that you can run windows telnet or hyperterminal to it at the same time as the dashboard and see whats going on, make an adjustment, then restart the logging and everything continues where it left off..
I wrote a "server" that attaches to the serial port, and the dashboard is basically a telnet client that connects and starts and stops the logging.. While its running, you can telnet into it (on the port I set on the batch file or port 23 by default) when the dashboard is running, you will see the log data going by, if you use hyperterminal or telnet to stop the logging and do something else, the dashboard will pause until you go back to the main menu and do a SHIFT-1 again, which the Dashboard will then resume when it sees the data stream.
It gets even better, if you have some sort of wireless connection for instance through a cellular modem connection or wireless access point, you could connect to it through the internet, or through a simple wireless lan setup and view the dashboard REMOTELY (and telnet into it and adjust the tuning REMOTELY)
I designed this originally to allow remote data logging and tuning while at the track... Don't forget the app isn't a secure server, so don't just put it up on any old port on the internet.. LOL You don't want someone retuning your car
Pretty nifty eh?
Pretty nifty eh?
Originally Posted by SoR
Wait, you can have your dash and hyperterm using the same serial port at the same time?
Do you have one-key (space?) logging or you have to click the button on the screen?
I actually demo'ed the remote tuning awhile back at a get together last year, using an accesspoint, a laptop in the car with the dashboard running, and another laptop that is the "Remote tuner"
I was hoping that UCC-3 would eventually allow a telnet connection in addition to a serial connection to leverage this feature. Unfortunately uploading maps requires that the engine not be running when uploading so its a bit of a moot point.
Originally Posted by dryad001
Sorry to bring a thread back from the dead but can someone send this to me? When My laptop crashed last week I lost everything, logs, maps, etc. It wasn't pretty. Now I'll be running XP instead of 98. And wireless in the garage YAY!!!
--Josh
Originally Posted by Airs
what did you write this in? going to give out source code?
I'm not intending to release the source code only because its a pretty straightforward adaptation of a communications application.
I'll get back to it at some point in the future, I didn't see a huge demand for it at the moment and the code I have does what I want, which is logs data and gives me a quick "view" of the data in real time (the dashboard portion)
