A christmas Gift.. UTEC Digital Dashboard
OK guys, I can't offer any support for the app, but extract the files into a directory, and run the batch file from that directory.. Its configured by default to use COM1 since most laptops use COM1..
No warranty or support.. Sorry, the BATCH file documents the command line options, and once you get the hang of it, you can connect to the listener (the portion that connects to the UTEC) With hyperterminal (Telnet) or several programs at the same time.. The Logger feature starts a log file with a time/date formatted filename, every time you start and stop the logging, and the files are saved in the same directory the app is run from. I kept it very simple since this program was intended to be used in an In-Car PC where it would be launched by other applications. Also, this app by default expects the TurboXS Tuner to be running, I'm not sure what will happen to the app or the logging if that data is unavailable. (If I recall correctly the AFR display will show the modified HZ output of the MAF instead)
Enjoy...
http://www2.longislandstreetscene.com:9449/utec.exe.zip
I WILL eventually start working on the app again if there's enough interest in it. This is a ZIP file, but its also a self extracting zip file, so if you want to run the installer (portable extractor) rename the file from UTEC.EXE.ZIP to UTEC.EXE
Consider this my christmas gift to the UTEC community.. Consider this application E-MailWare, that is, if you use it.. Drop me a PM or E-mail..
Enjoy...
Originally Posted by Jon H
MalibuJack - Could explain what the digital dashboard is?
Thanks.
Thanks.
I actually didn't think "digital dashboard" needed much explaination.. Its just a digital representation of a dashboard using available information from the logging.
Originally Posted by MalibuJack
I'm curious to know how many people end up using this with no trouble.. and the ones who do have trouble, what the problemw as, and what operating system.
Three cheers for Jack for his contributions to the UTEC community and the Evolutionm.net community.
-Adam
Yep, I do have a PPC version, but its not formatted for the average pocket PC, but for a HPC, I was developing both of these in parallel until the sourcecode diverged.. the problem is that working on both isn't really a high priority so the one I need to update for a particular reason usually gets my attention. The HPC code has been stable for some time, but because its formatted for a 640x240 screen, it doesnt use the 240x320 formatted layout and requires some work.
I released this because it seemed like it will serve people well for the time being.
Yep, I do have a PPC version, but its not formatted for the average pocket PC, but for a HPC.
