D-Jetro Power FC sensor kit.
Having ordered a D-Jetro PFC + Commander for my TME, i'm now realizing that MAP sensor and AIT are not included in the package, so now i have the problam to purchase them separately.
Anybody knows a web site where i can get them online, or even if i can use non Apexi sensors, like it's possible to do with other stand alone ecus?
Thanks in advance.
Gianluca.
Thanks in advance.
Gianluca.
I have them in stock actually if you need a set. I would also either recommend professional installation at a Power FC shop. There are certain settings in the Power FC that you need to change that you can not access with the commander.
Thank you very much, i've found the sensor and harness here in Italy, and i've also purchased a Datalogit, for having full operations available, as you suggested me i will let make the tuning by an expert in PFCs.....
Ok, i will let you know, i think it will take about 1 week for arriving from New Zealand.
As regards the car, i'm doing many mods, ( and spending a fortune...), i'm going to send some pics..
Gianluca.
Gianluca.
Originally Posted by Guru
Use 4000 for the PIM voltage offset on the datalogit before you start the car.
Thanks again!!!!
Fas4dr
21
Jul 28, 2016 04:22 PM
denial
Apr 12, 2006 02:17 AM
EVOlunchbox
Jun 26, 2004 11:23 AM
