Can someone check this data log for me??!!
Code:
RPM MAP Orig MAF TPS Load Knock ECU Timing Inj Duty Mod Timing Fuel Boost Mod MAF AFR 2151 -8.3 58 8 0 0 32.5 2.9 ECU. 0 ECU. 64 15.31 2156 -8.3 59 8 0 0 32.5 25.1 ECU. 0 ECU. 88 15.24 2240 -7.6 227 25 0 0 29.3 7.7 ECU. 0 ECU. 217 15.02 2198 -6.1 170 20 0 0 31.4 6.8 ECU. 0 ECU. 197 13.31 2216 -4.1 264 56 10 0 18.3 9.3 14.8 0 75 265 12.78 2255 -1.7 277 100 10 0 17.3 9.8 14.8 0 75 314 13.5 2311 0 294 100 10 0 16.1 12.2 14.8 0 75 283 13.75 2359 1 314 100 10 0 16.2 12.6 14.8 0 75 319 13.75 2413 1.7 330 100 10 0 16.3 12.6 14.8 0 75 356 13.47 2510 2.2 356 100 10 0 14.4 13.6 14.8 0 75 326 13.39 2550 2.7 387 100 10 0 13.4 14 14.6 0 75 341 13.42 2637 3.3 415 100 10 0 12.8 15.3 14.4 0 75 464 13.39 2725 3.9 459 100 10 0 10 17.1 14 0 75 484 13.31 2798 4.4 477 100 10 0 7.9 18.6 13.8 0 75 549 13.14 2866 5.1 538 100 10 0 5.5 20.1 12.6 4 75 716 13.06 2929 6 556 100 10 0 4 24.9 11.7 8 75 558 12.83 3013 7 618 100 10 0 2.8 28.9 10.7 10 75 623 12.33 3147 8.2 739 100 10 0 2.9 36.1 10.3 10 75 1004 11.77 3236 9.5 825 100 10 0 1.4 40.4 9.9 10 75 762 11.45 3360 11.4 943 100 20 0 -0.7 44.2 7.8 8.5 75 778 11.37 3494 13.5 1086 100 30 0 -1.6 49.4 7.8 7 75 889 11.34 3667 15.5 1106 100 30 0 -2.9 54.4 7.7 7 75 833 11.33 3822 17.5 1144 100 40 0 -1 56.3 6.9 6.8 75 1250 11.33 3921 18.7 1160 100 50 0 -0.7 57.4 6.3 7 75 1373 11.27 4065 19.4 1228 100 50 0 -0.8 58.4 6.6 7 75 1412 11.17 4208 19.9 1253 100 50 0 -0.8 63.6 6.6 7 75 1515 11.06 4391 19.9 1278 100 50 0 -0.4 63.6 6.5 7 75 1373 11.01 4480 19.7 1312 100 60 0 -0.3 65.9 6 7 75 1329 11.01 4655 19.7 1373 100 60 0 -0.3 70.5 6.1 7 75 1524 10.99 4748 19.6 1385 100 60 0 2.5 70.3 6.2 6.1 75 1404 10.89 4894 19.2 1432 100 60 0 3.9 69.2 6.3 1.6 75 1470 10.89 5042 19.2 1461 100 70 0 3.6 70 6.3 -2 75 1533 11.01 5151 19.1 1488 100 70 0 5.7 71.6 7.2 -2 75 1488 11.23 5257 18.9 1524 100 70 0 3.7 74.2 7.9 -2 75 1524 11.45 5446 18.9 1572 100 80 0 5.1 76.4 7.8 -2 75 1470 11.34 5537 18.9 1592 100 80 0 5.1 78.5 8.5 -2 75 1633 11.14 5698 18.7 1623 100 80 0 7.2 80.2 10.2 -2 75 1488 11.06 5807 19.1 1644 100 90 0 8.3 82 10.9 -3 75 1644 10.93 5910 19.2 1694 100 90 0 9.2 82.5 11 -3 75 1712 10.87 6027 19.2 1706 100 90 0 10.3 85 11.2 -3 75 1612 10.83 6172 19.2 1724 100 90 0 11.2 86.1 12 -3 75 1612 10.73 6277 18.7 1748 100 90 0 12.4 90.2 13.2 -3 75 1838 10.68 6397 18.4 1742 100 100 0 13.3 90.3 13.9 -4 75 1736 10.68 6485 18.4 1779 100 100 0 14.5 94 14.9 -4 75 1655 10.71 6626 18 1779 100 100 0 15.5 90.2 15.4 -4 75 1689 10.73 6706 18.4 1792 100 100 0 15.5 91.6 15.6 -4 75 1666 10.73 6816 18.6 1798 100 100 0 16.4 94.6 15.7 -4 75 1798 10.67 6930 18 1818 100 100 0 18.6 95 15.8 -4 75 1785 10.58 7002 17.7 1824 100 100 0 18.4 95.8 15.9 -4 75 1748 10.55 7092 17.4 1838 100 100 0 18.3 ---.- 16.4 -4 75 1879 10.4 7215 17.7 1851 100 100 0 19.6 99.8 16.7 -4 75 1760 10.2
Hey, attach it as a text file.. DLL isn't digesting it, neither is my other tool..
Sounds like your hitting a coolant enrichment mode.. are the engine temps higher than normal? I think the air is probably lost enough density that your in a different range of load sites than you normally tune in.
rraulston
28
Sep 21, 2005 09:55 AM
TrinaBabe
15
Jun 27, 2005 12:16 PM
MalibuJack
29
Sep 3, 2004 08:20 PM
